![]() | Home > In Car Electronics (L322) > Entertainment System Wont Switch On |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
disconnect the battery for about 30 minutes....details hwo to are in the wiki.. ... - .- -.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
I have had this with water in the Bluetooth module... There are loads of posts about this. You can bypass the Bluetooth module and it should fire up the rest of the kit.... If indeed that was the problem ! Previously..
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
Thanks Guys,
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
Mine did this!! Turned out to be the satnav unit failing! |
alan Member Since: 16 Sep 2012 Location: Somerset Posts: 45 ![]() ![]() |
Mine did this as well when I use the spare key all I do is pull the 2 fuses (not sure on the numbers off hand) and it works again. |
