Home > Maintenance & Mods (L322) > Just to be sure. Steering clunk.
Page 2 of 3 <123>
I have had the same thing... It turned out that after I had replaced the lower control arms, I had not fully tightened up the bolt that goes through the large rubber bush. It was allowing the slightest of movement that transformed into a loud crack when it moved. Only happened in carparks and pulling out of drives etc, all low speed.
Thumbs Up Previously..
Post #190547 25th May 2013 11:31am
Re your comments on the ARB links, I noticed this too when removing/replacing them. One side (can't remember which now, I think RHS) required significant effort on the ARB to remove/fit the droplink, whilst the other side was easy peasy. .
Post #190584 25th May 2013 6:24pm
Tayas
That sound just like what mine is doing. Can you be more specific as to which bolt? 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #190628 26th May 2013 9:26am
The big bolt that goes through the end of "number 9" that holds it onto the chassis. In my experience, every wobble, clunk and shake I have ever had has come from this arm/link. I replaced them, but the centre of the new bush was just slightly shorter than the old. When I tightened the bolt it was tight on the bracket but I had to make it tighter to bend the bracket in a bit to grip the bush.
Yours is probably slack or worn, I would tighten the bolt really tight before you try anything else. Thumbs Up
Ps.. I see you are a tuono man! I nearly bought one but went for the RSV.
Post #190630 26th May 2013 9:44am
Tayas
Thanks. I'll take a look once I'm back from Poland.
Tuono man for sure. I had an RSV Factory before but found it too hard on my wrists. The Tuono Factory has all the good bits of the RSV without any of the drawbacks. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #190666 26th May 2013 3:42pm
Whistle yes suncream. Was more when taking foot off of the brake and pulling off though. I have a similar issue to the op though and am ignoring it as it only happens at the extremes of lock. Personally i think it is the ns bottom ball joint with a little wear in it. Will get them to have a look as its due for a service soon. There is nothing that can't be fixed with a hammer😜😜
Post #190873 28th May 2013 9:22am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Disconnect the steering rack track rod ends from the hub but leave them on the rack grab hold of the bit behind track rid end and push / pull if the steering joint moves in / out its the inner track rod ends that are bolted to the rack under the big boot that are shot i had to replace both mine
Just to confirm i am not on about the ones that bolt to the hub its the ones that bolt to the end of the rack under the black boot Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #191348 30th May 2013 6:44pm
Tayas
Well, I just got back from the specialist and it needs a new steering rack. Great. £2.5k that's going to be.
Oh well, welcome to FFRR ownership I guess. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #192671 8th Jun 2013 11:15am
i'd be tempted to get a second opinion , just in case its not the rack.. ... - .- -.
Post #192686 8th Jun 2013 12:01pm
Budgie
If you do need a new steering rack then there are a few second hand on Ebay starting at £250.
They are all P/N QEB000083 which I think will fit the SC but I've not been able to confirm. Wink
Post #192692 8th Jun 2013 12:27pm
Tayas
Are all the racks on the FFRR the same regardless of model year? I thought some had variable ratio steering and some didn't.
I'm going to try and source a used or re-manufactured rack. £1700+vat is just bonkers for a new one. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #193037 10th Jun 2013 10:30am
Did you try a spanner on yir nuts?! Main dealer diagnosed my steering rack was away... Nothing wrong with it. Previously..
Post #193051 10th Jun 2013 11:20am
Tayas
I did. They didn't budge.
I might get a second opinion as others have suggested. Any recommendations for a place in the Berkshire sort of area? Rovertune are the guys who have diagnosed the rack by the way. I don't have any real reason to question their diagnosis but it's a shed load of cash. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #193075 10th Jun 2013 2:07pm
http://www.ebay.co.uk/itm/Range-Rover-L322...3cd1b69b00 Previously..
Post #193076 10th Jun 2013 2:16pm
Tayas
But is that the same rack as on a 2006 SC? I can't seem to find anything definitive. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #193087 10th Jun 2013 3:18pm
Page 2 of 3 <123>
