Home > Technical (L322) > Slight problem
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Slight problem
I've got a small issue, my hand brake light doesn't come on when my hand brake is applied also no park light when in park? They light up when I turn the ignition on? Along with air bag light and seat belt light?
Post #191230 29th May 2013 10:33pm
Curious... If you have tv/video on the front screen, does it switch off when you let the handbrake off and drive? Previously..
Post #191235 29th May 2013 10:41pm
Pull out the bottle holder in the centre and look down at the handbrake and see if the wire has broken off as usual... Thumbs Up
Post #191237 29th May 2013 10:41pm
Jammer600
I have tv but I don't think it works to be honest, not sure what frequency it is?
Will have a look by the bottle holder tomo cheers
Post #191239 29th May 2013 10:51pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
It wouldn't matter on mine, the bloody hand brake doesn't even work on mine... Laughing
Post #191450 31st May 2013 11:44am
Jammer600
Ha, mine doesn't to great effect, I found a plug near the hand brake which is a female type red, so in guessing that's that! Though my park, I can't really get beside the bottle holder easily, I can see down there but can't see any loose wires?
Post #191524 1st Jun 2013 9:11am
Jammer600
I've just re read your post ill try that cheers
Post #192582 7th Jun 2013 6:37pm
Jammer600
Any ideas why my park light isn't on? When it's in park?
Post #192583 7th Jun 2013 6:38pm
bad connection or bulb gone.. ... - .- -.
Post #192587 7th Jun 2013 7:06pm
Jammer600
It comes on, on start up then goes out with all the others, it's like it's turned off or something, like the seat belt light that doesn't stay on either if I leave the belt off?!!
Post #192641 8th Jun 2013 8:02am
i wouldnt worry about it to much if the handbrake works.. ... - .- -.
Post #192648 8th Jun 2013 9:09am
Seat belt chime/light only stays on after 07 facelift... PND lights inop may mean an issue with the gearbox switch...
Post #192679 8th Jun 2013 11:38am
Jammer600
Ok thanks, any pointers as to its whereabouts? Cheers
Post #192705 8th Jun 2013 2:08pm
