![]() | Home > Maintenance & Mods (L322) > RR Mudflap Fitting Guide - (Front and Rear) |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35876
excellent Trev, thankyou and wiki'fied.. ... - .- -.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Hmmm, nothing there about drilling holes for either front or rear ? .
| oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359
Looks very much like the fitting instructions shown on TOPIx. |
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217
http://topix.landrover.jlrext.com/topix/vehicle/index?cat=OWNER#
| Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267
I can never manage to get into Topix....I only get as far as the nice pretty Silver RR.
Here we go, pdfs direct from Topix, with hole drilling, for '02-'05 spec, |
In TopIx Select Model Select Year Click "Find" Click "Owner" Select "Accessory fitting instructions" Ignore all other options by the way. |
Thanks guys..
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
So is hole drilling only required for 02 to 05? I drilled mine and its an 08. Hate drilling holes in my RR .I ask because instructions posted above by Trev states no drilling. Present :2008 TDV8 HSE
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
. . . . Fitted fr & rr flaps on my last FF ('06 MY).
I've also done the rear ones.... Yes easy.. Also there is a good Youtube guide on this (googled L322 mudflap fitting).. and it shows drilling holes, wasn't happy doing this... measured over 10 times before making the holes.....
I have done mine. What I did was fit the brackets and then drill through the inner wing on the inner fixings if that makes sense. If you don't as you tighten the screw it pushes the inner wing skin back leaving a large gap if that makes sense. Present :2008 TDV8 HSE
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Great post, need to remove my old ones and fit the newer rears to mine. Tom
Hi, Spent a couple of hours fitting the front ones today.. Stripped down the inner wing and took off the bottom panel.. As suspected no metal brackets behind.. and not supplied in the kit... Check before you buy what's in the box....
| All times are GMT |
