Home > Maintenance & Mods (L322) > RR Mudflap Fitting Guide - (Front and Rear)
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Includes Front and Rear Mud flap Fitting guide
Regards
Trev
Post #192158 5th Jun 2013 12:41pm
excellent Trev, thankyou and wiki'fied.. ... - .- -.
Post #192159 5th Jun 2013 12:58pm
Hmmm, nothing there about drilling holes for either front or rear ? .
Post #192173 5th Jun 2013 1:52pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Looks very much like the fitting instructions shown on TOPIx.
Post #192181 5th Jun 2013 3:13pm
duckworthparts
Site Sponsor
http://topix.landrover.jlrext.com/topix/vehicle/index?cat=OWNER#
direct link for topix fitting instructions for Range Rover, click home to change model year etc You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #192186 5th Jun 2013 3:33pm
Trev18
I can never manage to get into Topix....I only get as far as the nice pretty Silver RR.
When searching on here could not find anything on front Mudflaps.... without ending up somewhere else... Newbie only trying to help.. ?????? Bow down
Post #192230 5th Jun 2013 9:09pm
Here we go, pdfs direct from Topix, with hole drilling, for '02-'05 spec, Wink
Front: http://www.fullfatrr.com/gallery/albums/us...dflaps.pdf
Rear: http://www.fullfatrr.com/gallery/albums/us...dflaps.pdf
Good idea for a post and a wiki'd one at that Trev18 Thumbs Up .
Post #192233 5th Jun 2013 9:55pm
oldcro
In TopIx
Select Model
Select Year
Click "Find"
Click "Owner"
Select "Accessory fitting instructions"
Ignore all other options by the way.
Post #192256 6th Jun 2013 12:21am
Trev18
Thanks guys..
Seems I don't have the metal brackets that are shown in picture 2 - 6...... Big Cry
Post #192301 6th Jun 2013 10:28am
Googsy
So is hole drilling only required for 02 to 05? I drilled mine and its an 08. Hate drilling holes in my RR .I ask because instructions posted above by Trev states no drilling. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #192311 6th Jun 2013 11:27am
TugRR
. . . . Fitted fr & rr flaps on my last FF ('06 MY).
Rears - easy peasy.
Fronts - pain in the ar5e. The brackets (not shown in the above illustrations) were a pig to fit necessitating partial removal of the inner wing.
That being said, they considerably cut down on muck up the doors & sills -
Thumbs Up Where do you go after one of these . . . ?
Post #192313 6th Jun 2013 11:35am
Trev18
I've also done the rear ones.... Yes easy.. Also there is a good Youtube guide on this (googled L322 mudflap fitting).. and it shows drilling holes, wasn't happy doing this... measured over 10 times before making the holes.....
The initial issue that started this post was that I was not sure how the fronts fitted.....
I have still got these to do...... I am going to leave it until the weekend where I can take it nice and easy with the install... Going to do more research on if I need the brackets shown, or are they already behind the inner wing.. etc
Trev
Post #192317 6th Jun 2013 11:50am
Googsy
I have done mine. What I did was fit the brackets and then drill through the inner wing on the inner fixings if that makes sense. If you don't as you tighten the screw it pushes the inner wing skin back leaving a large gap if that makes sense. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #192320 6th Jun 2013 12:00pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Great post, need to remove my old ones and fit the newer rears to mine. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #192368 6th Jun 2013 3:39pm
Trev18
Hi, Spent a couple of hours fitting the front ones today.. Stripped down the inner wing and took off the bottom panel.. As suspected no metal brackets behind.. and not supplied in the kit... Check before you buy what's in the box....
Local DIY shop had a solution " Galvanised larger self tapping screws and matching metal edge secure bolts (all for a £1.00)
Front Pic
Rear Pic
Trev
Post #192783 8th Jun 2013 8:35pm
