![]() | Home > Technical (L322) > Max Aircon - No Aircon On RHS SOLVED! |
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
Gonna start with a regas - IIDTool is telling me the evaporator temp was 23 deg - presume this should be close to zero and gas pressure was 10 (presume this is in PSI) - tested on running system with max aircon on for 10 mins |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
If you have chilled air coming out of one set of vents it tends to suggest the cooling is working.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Does anybody know how to get at the TEMP SENSOR(s) to clean? |
It's located behind the small grille on the upper facia panel.
There is chilled air comming out but pretty sure its not 4 degs |
You need to measure right up against the grille, I use a probe thermometer pushed into the grille opening.
Thanks do you think an air gun blast may clean it without dismantling? |
No I'm afraid not. The dirt tends to get compacted overtime and more or less has to be scrapped off.
IIDTool will give you a live reading from that sensor .... under 'cabin temp' |
Had system regassed today by my local 'specialist' - now perfect, IIDTool reports pressure of around 15-16 so although it was low it wasn't too bad and most importantly the evaporator now shows 3.2 degrees.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
result |
Its lovely and hot here in Hereford (except of course in my car where its positively arctic) |
you'll have rain soon cos its raining here in swindon. ... - .- -.
| All times are GMT |
