Home > Technical (L322) > Max Aircon - No Aircon On RHS SOLVED!
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Strange one this, when 'max aircon' is on there appears to be no chilled air coming from the vents on the RHS of the vehicle yet the LHS is fine.
Even the center vent has a distinct difference between the left and right side of it, have used IIDTool to confirm both left and right climate knobs are outputting the correct desired temp and that there are no other faults.
Gut instinct suggests a flap not moving as it should.
Anyone had this issue?
Post #192212 5th Jun 2013 6:07pm
Katash
Gonna start with a regas - IIDTool is telling me the evaporator temp was 23 deg - presume this should be close to zero and gas pressure was 10 (presume this is in PSI) - tested on running system with max aircon on for 10 mins
Post #192235 5th Jun 2013 8:57pm
If you have chilled air coming out of one set of vents it tends to suggest the cooling is working.
Might be worth measuring the temperature of the air coming out of the cold vents when on max setting.
Should get down to about 4C if cooling is operating correctly.
Post #192275 6th Jun 2013 7:28am
Does anybody know how to get at the TEMP SENSOR(s) to clean?
Post #192282 6th Jun 2013 7:55am
It's located behind the small grille on the upper facia panel.
Accessed as per vid below.
Post #192287 6th Jun 2013 8:20am
Katash
There is chilled air comming out but pretty sure its not 4 degs
Post #192288 6th Jun 2013 8:21am
You need to measure right up against the grille, I use a probe thermometer pushed into the grille opening.
If it's not that cold you probably need the gas checked.
Post #192291 6th Jun 2013 8:28am
Thanks do you think an air gun blast may clean it without dismantling?
Post #192294 6th Jun 2013 8:45am
No I'm afraid not. The dirt tends to get compacted overtime and more or less has to be scrapped off.
A dry paint brush works ok.
Post #192298 6th Jun 2013 8:58am
Katash
IIDTool will give you a live reading from that sensor .... under 'cabin temp'
Post #192307 6th Jun 2013 9:48am
Katash
Had system regassed today by my local 'specialist' - now perfect, IIDTool reports pressure of around 15-16 so although it was low it wasn't too bad and most importantly the evaporator now shows 3.2 degrees.
Max aircon is now working perfectly and there is no noticeable difference between sides.
I have a theory, probably wrong tho but I'm guessing by looking at the diagrams of the system that the evaporator inlet may be on the LHS (looking from seats towards engine) and that the low refrigerant was expanding in the entry to the evaporator but only really being effective towards the LHS of it, perhaps the temp sensor was on the RHS of the evap and hence that's why the evap temp was showing high but airflow through the LHS was being chilled and the RHS wasn't.
I took the pollen filter out and checked out the RAM and Recirc flaps first as I thought 1 may be stuck but they were operating fine and the mechanic confirms the system was fine and only required a regas.
Post #192533 7th Jun 2013 11:49am
result Thumbs Up ..now all we need now is some hot weather.. Laughing ... - .- -.
Post #192535 7th Jun 2013 11:51am
Katash
Its lovely and hot here in Hereford (except of course in my car where its positively arctic)
Post #192536 7th Jun 2013 11:53am
you'll have rain soon cos its raining here in swindon. ... - .- -.
Post #192537 7th Jun 2013 11:54am
