Home > eBay & Bargain Spots > T91 park heat remote fob
Page 2 of 5 <12345>
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
GraemeC - me too, I had a brand new one supplied with the car as it was missing and i pointed it out to the dealer. But at £16 I was compelled to buy another - for a rainy day! Whistle
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #192574 7th Jun 2013 4:50pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Ditto Rolling Eyes
Though my original one won't operate my heater and I can't find an instruction set on this forum to get it to pair with the car. I've been pulling fuses and plugs, waiting 5 secs, 10 secs, pressing "Off" within 5 secs of powering back up but all to no avail. Seems the home made remote pairing only works on earlier i e pre MY11 cars Sad
Still, it's going in to the dealers in a couple of weeks for a close inspection and a few extra bits added so I'll get them to do it. Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Previously: 4.4 TDV8 Vogue Baltic Blue MY11
Post #192603 7th Jun 2013 8:45pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Job Done! Very Happy
Ordered the T91 from as per post above day before yesterday. Arrived today. Tried to pair by pulling fuse 59, didn't work. So took off the rear fuse box. Looked daunting but once the three screws are out it pulls away nicely to reveal the receiver. Thanks to good info on this site (see links above) I identified the multi-plug and although it was difficult I managed to get it out. Knowing it can be done allows a bit more force than I would otherwise have used. A front to back movement seemed to free it up. Left it unplugged for a couple of minutes then plugged it back in and pressed the off button on the new remote for a couple of seconds. Works fine. Also tried the old T90 which remains paired.
I was expecting nightmares and it turns out it was easier than I thought! A couple of glasses of nice red whilst watching the Lions beat the Queensland Reds may have helped confidence levels. Anyway job done and thanks to those who put up great advice earlier! Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #192709 8th Jun 2013 2:00pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Got mine today too Thumbs Up the 2010+ looks like a different pairing process as I can't see a fuse for the FBH front or back Sad manual says trip to a dealer to get programmed Crying or Very sad anyone know if it can be done without programming at a dealer ? 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #192711 8th Jun 2013 3:07pm
Nomad
As you can see from the posts above, taking out the fuse rarely works. You have to take off the whole fuse box and retaining bar in the rear compartment. Once you've done that you can get access to the receiver at the back. Unplug the multi plug for a couple of minutes. Plug it back in then press the off button on the remote for a couple of seconds... this assumes 2010+ is the same. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #192712 8th Jun 2013 3:18pm
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
On my 2008MY TDV8 it was Fuse 16 in the rear fuse board.... worked like a charm.... with the added bonus of being much easier to get to !! 2011 Stornaway Grey 5.0SC Autobiography
Post #192717 8th Jun 2013 3:41pm
jez000
Thanks Nomad, ill take a look to see if I can find the T91 receiver behind the rear fuse box then. Thumbs Up 2021 P400 Silicon Silver AB
Post #192718 8th Jun 2013 3:42pm
Baron
Let me know what you find coz I can't work out how to do it on my 11MY. There's a black box with T91 on a label attached to what looks like a fibre optic cable connected to it. That box isn't behind anything, it's to the right of the rear fuse box.
Yours,
Confused.com Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Post #192795 8th Jun 2013 8:58pm
jez000
Wow that was easy, removed the cover on the right hand side of the boot, pulled the power out of the T91, left for 5 secs, plugged power back in then held the off button for a couple of secs on the remote as described earlier and that's it, takes less than a minute. Thumbs Up 2021 P400 Silicon Silver AB
Post #192897 9th Jun 2013 1:47pm
Baron
So, just to be clear, the Telstar T91 black box to the right of your fuse box in the boot of the car. You unplugged the black 3 wire connector, left for over 5 secs, plugged it back in and pressed the off button on your heater remote less than 5 secs later and all was well?
Did you do this with the ignition on or off?
I've tried it with the ignition off and I still can't start my heater. Whenever I press either button the remote LED flashes rapidly between red and it looks like yellow. No constant red or green illumination. Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Post #192925 9th Jun 2013 4:58pm
Nomad
I think yellow means the remote battery is on the way out. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #192935 9th Jun 2013 5:12pm
jez000
Hi Baron, I did it with the ignition off but within a minute of unlocking the car, Then as you described I pulled the 3 wire connector from the T91 Telestart box left it 5secs then plugged it back in then within 5 secs pressed down the off button for about 3 secs. The unpaired remote will flash more rapidly but when it's paired it will go solid. As nomad mentioned if the light goes orange the battery is on the way out. 2021 P400 Silicon Silver AB
Post #192941 9th Jun 2013 5:36pm
Baron
Thanks jez, looks like my poor remote battery is preventing me from pairing. I'll get a new one tomorrow and start again. Thanks for clearing up the pairing procedure for a MY11 car. The location of the electronic gubbins seems to have been moving around the boot of the car almost with each successive year! Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Post #192944 9th Jun 2013 6:21pm
My 1st one arrived this morning Smile
A lot smaller than i thought it would be but does use a small button battery so i guess the range isn't as big as the older fobs...
 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #193074 10th Jun 2013 1:06pm
dave699
Collected mine from sorting office this morning.
It is an additional one to leave at work.
Pairing is a doddle. As described above, also original remote remains paired when you pair the new one Thumbs Up
Had it, loved it!
2007 Vogue SE TDV8
Post #193080 10th Jun 2013 1:50pm
Page 2 of 5 <12345>
