Home > Technical (L322) > Replacing drop links / anto rollbar links
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Is there a 'how to' or wiki anywhere on this? I've got a front end clunk that has been diagnosed as front drop links.
Interested in doing the job myself unless it requires a lift etc.
Cheers,
Ben
Post #154319 29th Nov 2012 12:10pm
Drop link goes from the strut to the anti-roll-bar
Easy job but you will need to remove the wheels to allow access
Post #154339 29th Nov 2012 1:22pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I just put mine on off-road setting and turned the wheel on full lock as I did each side - no need to remove the wheel - literally took me 10 mins to change..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #154464 30th Nov 2012 9:29am
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Something interesting happened the other day when I removed one of my drop links to check for wear in the ball joints and found I had to put the suspension into fullheight setting otherwise the bottom joint was under tension. In other words the nut could be undone but couldnt remove the threaded portion unless the car was in off road setting. The same when replacing (having ordered 2 new ones in the meantime!).
Now surely the ARB should be under no rotational force unless one wheel is higher than the other? This was with the car sitting on the flat and all wheels on the ground and visibly at least the corner heights are all level.
So why would the ARB be under torsional force??! Any ideas anyone?
T
Post #193172 10th Jun 2013 8:01pm
^^ i suppose that if one of the wheels was even slightly higher than the other then there would be some tortional stress on the roll bar. So the suspension calibration would have to be dead on and the floor dead level to have the roll bar under equal torsion on both wheels.
I think. There is nothing that can't be fixed with a hammer😜😜
Post #193194 10th Jun 2013 9:28pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
Very easy job to do, even for DIY beginners. Just remember to take careful note of the position of the specially hardened washers mate. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #193199 10th Jun 2013 9:34pm
tomthevet
Sorry I wasnt asking how I was asking about the apparent preload on the bar. On any other car I have done the ARB has been in a neutral position regardless of load as long as the wheels are level. I think maybe northern monkey is right in that although it looked level it wasnt.
Post #193200 10th Jun 2013 9:37pm
Whether you take the wheels off or not, you need an 18mm longish socket & breaker bar/ratchet and an open ended 18mm spanner.
The open ended spanner fits onto a flat on the "blind" side of the ball joints enabling you to undo the nuts on the splines. More important to hold the position of the splines/ball joints when doing up the new one.
Make sure the special hardened washers goes back in the same place.
As stated above, one or both sides may be under some load on the ARB, use a long bar or length of wood to lever the ARB either up or down to release the splines from the fixing holes.
This is all easier to get at with the wheels off, jack up correctly and get an axle stand under the subframe! .
Post #193203 10th Jun 2013 10:02pm
tomthevet
Am I going mental here? Maybe I have been working too hard.
Post #193205 10th Jun 2013 10:13pm
edward.barry
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
Hi Folks, did the drop links myself recently, handy enough, except I didn't take note or the position of the washers, anybody know off hand how they are supposed to be positioned.
Regards Ed 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
2005 Subaru Legacy Outback (the wife's)
1981 2.5 Opel Commodore
Post #194183 14th Jun 2013 4:42pm
Laughing
The same place as they were before you took them off!
(Yes, I fell for it!) .
Post #194295 14th Jun 2013 9:14pm
edward.barry
Thanks Joe, as my memory isn't what it used to be do you remember, nut or bolt side of the drop link? Now if I could just remember where I abandoned the car. Ed 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
Post #194362 15th Jun 2013 9:32am
Googsy
Im doing mine today. I believe washers are bolt side not the nut side. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #194386 15th Jun 2013 10:48am
The hardened washer goes on the ball joint side (you are normally helped by the markings left on the washer which show the "flats" on the bolt). There is only one washer (?), for the top joint on the front drop links.
So, in order
Drop link ball joint
Washer
Strut mounting point
Nut .
Post #194387 15th Jun 2013 10:49am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
If it hasn't be said, buy genuine, fit once and forget (well for a few years) Smile
Post #194392 15th Jun 2013 11:11am
