![]() | Home > Technical (L322) > rear wiper arm question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
seems to be the correct part number , does the spline bit in the old arm come out and then fit into the new arm.. ... - .- -.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
no its not a removable part its cast as part of the old arm
i've googled that part number and loads have it specified for the l322, maybe ducky Dan could enlighten the situation but he's probably off till monday.. ... - .- -.
scorpiont10 Member Since: 30 Aug 2012 Location: Mansfield Posts: 6 ![]() ![]() ![]() |
There were no splines on mine when I replaced it. The arm is cast aluminium, and I figured that the splines on the shaft imprinted onto the old arm. I haven't had any problems so far |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I don't think they have splines. I think the taper and the nut create the splines in the wiper arm. That way if anything stops the motor the sacaficial bit is the wiper arm. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Its an imprint made after its fitted... |
