Home > Technical (L322) > rear wiper arm question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
seems to be the correct part number , does the spline bit in the old arm come out and then fit into the new arm.. ... - .- -.
21st Jun 2013 6:35pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
no its not a removable part its cast as part of the old arm
21st Jun 2013 6:36pm |
i've googled that part number and loads have it specified for the l322, maybe ducky Dan could enlighten the situation but he's probably off till monday.. ... - .- -.
21st Jun 2013 6:38pm |
scorpiont10 Member Since: 30 Aug 2012 Location: Mansfield Posts: 6 |
There were no splines on mine when I replaced it. The arm is cast aluminium, and I figured that the splines on the shaft imprinted onto the old arm. I haven't had any problems so far |
21st Jun 2013 9:03pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I don't think they have splines. I think the taper and the nut create the splines in the wiper arm. That way if anything stops the motor the sacaficial bit is the wiper arm. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
21st Jun 2013 9:21pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
22nd Jun 2013 9:44am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Its an imprint made after its fitted... |
22nd Jun 2013 10:44am |
