![]() | Home > Technical (L322) > steering column adjuster. |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
Ok folks, finally got around to doin this job after getting a new nut from meerbucsh.
rejo Member Since: 10 Feb 2013 Location: Netherlands Posts: 28 ![]() |
inbus bolts .... are allen bolts |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
hi muffster, in my gallery you can see a build-out steering column: there is the spindle to see, and there are two (you can see only one of them) allen? inbus bolts between the motor and the spindle. Screw them out, but not complete, only 70%, then you can push down the spindle incl. the old plastic nut. Then screw out the old plastic nut, and screw on the new one, and complete all parts. Believe me, a very easyjob for me, because of 20 times done. If first time, you will need one hour, I need now 20 minutes. The tools are normal tools ,each gentleman has them. Best regards, Uli! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Meerbusch
Look in the blue/grey part of my posts... |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
I've just done this job, good job I was alone as language got decidely ropey for a while. Dont make the mistake I made and uscrew the allen bolts too far - one came right out and was an absolute **** of a job to get it back in! However the nut I bought from meerbusch did the job perfectly so I can now go 'up and doon' and 'in and oot'!!! This is not a job for anyone with big hands or muscular arms - bit of a tight fit in there........... |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
fitted the replacement part from Meerbusch but hasn't solved the problem the reach function still stops at different heights every time. I have tried reprogramming the memory function but doesn't make any difference, anyone got any other ideas what the problem could be. Could the motor be waring out. When i put the key in the wheel tilts and comes forward then stops, i can then use the stalk to move the wheel manually into position but doesn't return to that point next time.
out of interest the old nut that i removed from my steering column had a brass thread wasn't plastic.
bump
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35685 ![]() ![]() |
disconnect the battery for a full reset? [you've probably done that though] ... - .- -.
