![]() | Home > Technical (L322) > Front strut replacement - in pairs? |
Safety above all, especially when you are mucking about with pressurized gas and fluids is a very smart approach. After that your biggest problem is rusted bolts/nuts on the front suspension. I hope that yours don't put up too much of a fight (like my rear suspension did).
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
All done. We have a bouncy lifty Fatty once again. No dash errors, all working as Solihull intended.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
The stuff about the cross over valve pipes is also in my wiki post on front struts. Storey Wilson's video gets it wrong, but at least he puts up a caption to correct it |
Ah, that was what confused me - and the fact that the crossover valve on mine is not the same as the one in the video. Mine has a yellow, a blue and a black hose. Yellow = OSF, Black = NSF and Blue I presume is the feed. |
Glad to hear you are mobile again. Hopefully for a long long time |
Thanks all.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
What's the issue with the Dunlops then? I fitted a pair in March from Island 4x4 and they're ok so far? |
I went for the Delphis after reading around the web that the Dunlops don't last as long as you would expect them to - don't know if it's true or not but decided not to take the chance. On top of that Island only had the Delphis in stock anyway. |
