Home > Maintenance & Mods (L322) > TDV8 4.4 oil filter
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
TDV8 4.4 oil filter
Where is the engine oil filter on a 2012 TDV8 4.4 litre and how do I get to it?
A long sad story, but I need to do an oil change after a poor service experience. Big Cry
Post #196202 25th Jun 2013 10:15pm
Vogue
Believe it or not, it's at the top of the engine in the middle at the back, under a cover. It's also upside down! Make sure you - And doubly sure check the seal is put back in place. Mine wasn't by some thick idiot of a LR tech iguana with greasy hair, bad breath and dandruff! Result sprayed oil everywhere! He no longer works there! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #196307 26th Jun 2013 6:51pm
Badly replaced Oil Filter can also result in low oil pressure and catastrophic failure....
Post #196309 26th Jun 2013 6:57pm
Vogue
Exactly, fortunately mine was just a slight leak.
Post #196311 26th Jun 2013 7:01pm
oldcro
Thanks Vogue, I'll look out for the seal and make sure the filter is fitted upside down. Will check the old filter and replace the same way. Thumbs Up
Post #196313 26th Jun 2013 7:02pm
Vogue
Apparently it is a very regular occurrence. I would call it a design fault if even a pleb of a tech cannot complete such a simple task.
Land Rover are you listening! ??? Because its costing you money and inconvenience! And plissing your customers off.
Oh and we are running 8 of your vehicles here.
Rolling Eyes 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #196314 26th Jun 2013 7:05pm
oldcro
Gazellio, your post is doing wonders to my confidence, fortunately a mechanic (Not Landrover trained) will be on hand to stop any obvious mistakes.
Post #196318 26th Jun 2013 7:12pm
Vogue
Not LR trained is probably a bonus! Judging by some if the experiences we have had
Post #196319 26th Jun 2013 7:13pm
