|  | Home > Maintenance & Mods (L322) > Removing/replacing CV joint |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    |
 Hiya, seen lots of posts on here about getting the stub shaft of the CV joint out of the hub... its a press fit and is made worse by corrosion and age. I intend to try using a hub tool in reverse, to push the shaft through. Failing that, I will follow 47p2's advice and try pushing it out  with a blunt tool in an air hammer.
|  1st Jul 2013 12:23pm |
| hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870      | I can't really picture where you mean but when I did my lower ball joint it was a pig, but released with advice found on here. Basically used a jack to push it upwards from underneath (almost lifting the car) then some heat made it ping out.
|  1st Jul 2013 5:25pm |
| ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341    | Hi Les when I had both sides out the other week replacing the wheel bearings I drove the axle out using my SP 1500 hydraulic and bolted it to 4 wheel studs. I drove them out very easily. Putting them back was a right sod, in the end I released the CV boot and tapped them in with a copper/leather hammer. I believe the correct tool is a very narrow side walled threaded tube that screws onto the end of the axle and draws it through the hub.
|  2nd Jul 2013 5:50am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | I can sell you a pusher for £250... They are a copy of a Land Rover tool i borrowed and our engineers made 6 sets out of a superior grade of steel so they are very very strong!
|  2nd Jul 2013 7:58am |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    | Hi Craig, hi all, thanks for the advice, good to know that the shaft ought to pull back in with the beeeeg nut.... I have made a pusher out of 8 mm plate that bolts over the wheel studs and has a 16mm threaded boss in centre, not tried it yet as podding down here, will post pic, assuming it works!! | ||
|  2nd Jul 2013 7:19pm |
| Posting Rules
