![]() | Home > Maintenance & Mods (L322) > Removing/replacing CV joint |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Hiya, seen lots of posts on here about getting the stub shaft of the CV joint out of the hub... its a press fit and is made worse by corrosion and age. I intend to try using a hub tool in reverse, to push the shaft through. Failing that, I will follow 47p2's advice and try pushing it out with a blunt tool in an air hammer.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I can't really picture where you mean but when I did my lower ball joint it was a pig, but released with advice found on here. Basically used a jack to push it upwards from underneath (almost lifting the car) then some heat made it ping out.
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Hi Les when I had both sides out the other week replacing the wheel bearings I drove the axle out using my SP 1500 hydraulic and bolted it to 4 wheel studs. I drove them out very easily. Putting them back was a right sod, in the end I released the CV boot and tapped them in with a copper/leather hammer. I believe the correct tool is a very narrow side walled threaded tube that screws onto the end of the axle and draws it through the hub.
I can sell you a pusher for £250... They are a copy of a Land Rover tool i borrowed and our engineers made 6 sets out of a superior grade of steel so they are very very strong!
Hi Craig, hi all, thanks for the advice, good to know that the shaft ought to pull back in with the beeeeg nut.... I have made a pusher out of 8 mm plate that bolts over the wheel studs and has a 16mm threaded boss in centre, not tried it yet as podding down here, will post pic, assuming it works!! |
