![]() | Home > Maintenance & Mods (L322) > rear suspension on its bum |
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
Help please
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
Gutted piping or height sensor it would be good to read faults |
Not much info to go on here. Lots of possible causes so you need to eliminate them one by one.
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
To change the compressor is a easy job it's in the boot under the spare wheel but I would get the fault codes read to see what the fault is. My compressor failed but it just locked out the suspension so it was at normal ride hight so if yours is dropping it sounds like you have an air leak or a valve not doing its job.
The info screen near the speedo does not report any faults, are the error codes only read with a reader. There is no suspension inactive message. |
Start with a battery reset... If there is no fault in the computer, there is no point plugging it in...
Cheers all I will have a good look today, them a good lie down when I work out the cost to repair |
Had a good look today and can't find a thing wrong. Suspension works great at all heights with no air loss. Looks like a random error so not touching it just in case. |
