Home > Maintenance & Mods (L322) > rear suspension on its bum
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Help please
The rear suspension has dropped to the bottom. There is no message on the display and the controls
Seem to be active. This happened as I was driving along luckily 1/2mile from home. Gutted need the car tomorrow.
Post #197796 6th Jul 2013 2:03pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Not much info to go on here. Lots of possible causes so you need to eliminate them one by one.
A failed compressor, a leak somewhere in the air suspension pipework, leaky airbag?
Can you get it to offroad height? 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #197799 6th Jul 2013 2:28pm
adigorn
Gutted piping or height sensor it would be good to read faults
Post #197802 6th Jul 2013 3:21pm
Mph28mph
A failed compressor, I can hear the compressor working
a leak somewhere in the air suspension pipework, leaky airbag I will check these today
Can you get it to offroad height? No it won't raise to off road I have how ever got it to normal height and level.
It takes ages now to raise and fall
Does the mean the compressor is shot?
Is it a straight forward swap old for new?
Post #197850 7th Jul 2013 8:32am
RCusden
Wales
To change the compressor is a easy job it's in the boot under the spare wheel but I would get the fault codes read to see what the fault is. My compressor failed but it just locked out the suspension so it was at normal ride hight so if yours is dropping it sounds like you have an air leak or a valve not doing its job.
Roger
Post #197851 7th Jul 2013 8:42am
Mph28mph
The info screen near the speedo does not report any faults, are the error codes only read with a reader. There is no suspension inactive message.
Post #197852 7th Jul 2013 8:55am
Start with a battery reset... If there is no fault in the computer, there is no point plugging it in...
Then if the problems persist, with the car running i would press the "off road height button" then if it wont go up? get a jack out and jack up under the towbar slowly (listening for air)
It will be a rear bag holed is my bet... Whistle
Post #197856 7th Jul 2013 10:13am
Mph28mph
Cheers all I will have a good look today, them a good lie down when I work out the cost to repair Big Cry
Post #197861 7th Jul 2013 10:46am
Mph28mph
Had a good look today and can't find a thing wrong. Suspension works great at all heights with no air loss. Looks like a random error so not touching it just in case.
Post #197937 7th Jul 2013 10:52pm
