![]() | Home > Maintenance & Mods (L322) > Check coolant level and PDC help |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Welcome... Coolant - need to post id TD6 or V8...
vogue12345 Member Since: 25 Jun 2013 Location: UK Posts: 18 ![]() |
Hi Craig
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
If you are loosing coolant but cant see where then check your engine oil cap for signs of 'mayonase' indicating a head gasket failure .... althoughmy guess would be a tiny crack in your expansion bottle .... people have reported this causing the coolant to leak out when pressurised. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
re the sensor, its a common problem that the wiring gets chaffed on the off side outer pdc, check the wiring and you might find the problem.
^+1 just buy a new rear loom for £20 and whip off the back bumper & change it. 30 minute job and 90% chance of a permanent fix. |
Hi guys
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
prob a leaking radiator. they leak from the lower left when looking from the front. The coolant then gets blown over the hot engine and gives no indication of a leak. eventually it gets bar enough to form a puddle unset the car. Another area prown to fail is the water pump. Again no signs due to the fan blowing coolant overt the engine. check the rear hoses and the valley pan. They fail but not as likely as the other 2. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks for the info Rob - will look into it. If it is water pump or leaking radiator would that mean a new one then?
Any MAIN DEALER but Dan @ Duckworths will be cheapest.
Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78 ![]() ![]() |
Agree with Rob When my rad went it was very difficult to spot! Have you taken the plastic under carriage under the engine if your leak is not enough it would pool on the tray !! Also don't rule out the expansion bottle when I spotted mine it was a hairline and fine spray when fully pressurised. The water pump will either leak around the gasket or where it connects on the pulley but again a good view is when the under tray is off !! Also last thing your sensor in the expansion bottle could be faulty or too much crap around the probe. Just remembered it will bong if you haven't got a 50/50 mix with the coolant ! Good luck |
Hi guys
