Home > Maintenance & Mods (L322) > What to do?
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
What to do?
I fly out week today for my hols for 2 weeks what should I do about battery have been told to disconnect it ?
Post #198947 15th Jul 2013 6:55pm
have you had problems with it? if not ,leave it alone... ... - .- -.
Post #198950 15th Jul 2013 6:59pm
Dave ray
Thanks for the fast Reply will do that then battery is ok I think other than my radio screen has gone blank but it still works ?
Post #198953 15th Jul 2013 7:02pm
Pull FUSE 49 front fusebox in cubby and get out ans lock the car. Wait 5 minutes unlock fit the fuse and start the car. May work normally does.
Post #198955 15th Jul 2013 7:03pm
just make sure there's no gadgets left plugged in and with this nice warm weather it should be ok....might also be worth asking where you park it if they have a jump start facility, just in case.. ... - .- -.
Post #198957 15th Jul 2013 7:04pm
Dave ray
Thanks for the responses
Post #198959 15th Jul 2013 7:07pm
Dave ray
Just pulled fuse 49 and screen is back on thanks
Post #198960 15th Jul 2013 7:16pm
Post #198962 15th Jul 2013 7:18pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Maybe get a solar charger?
Post #198963 15th Jul 2013 7:41pm
Dave ray
While where at it drivers side rear entertainment screen not working is there a fuse for that ?
Post #198964 15th Jul 2013 7:42pm
Probably but not sure which....
Post #198965 15th Jul 2013 7:50pm
Gruute
Belgium
Put a charger on it. Ctek MXS 5.0. Works perfect.
I have 4 of them constant in use.
http://www.ctek.com/int/en/chargers/12v 2017 Range Rover Vogue TDV8 silicon silver
2011 Defender 90 2.4 TDCI Nara Exclusive
2008 Porsche 911 997 4S Black/black
1970 Porsche 911T 2.2 in restauration
1980 Toyota Land Cruiser BJ40 concours winner
Post #199046 16th Jul 2013 11:40am
ebajema
I am leaving for 4 weeks and have done so before and it always started first try. So I wouldn't worry about it too much unless you have been having battery problems. If you have it in a garage it is easy to put it on trickle charge then I suggest to do so, just to keep the battery topped up. It may be freezing again when you come back Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #199049 16th Jul 2013 2:09pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
My DB7 had this battery problem, after 2 weeks...dead. Bought a solar charger put it in the cigar lighter and problem gone.
They realy work well.
Post #199060 16th Jul 2013 3:10pm
