![]() | Home > Maintenance & Mods (L322) > What to do? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
have you had problems with it? if not ,leave it alone... ... - .- -.
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 ![]() ![]() ![]() |
Thanks for the fast Reply will do that then battery is ok I think other than my radio screen has gone blank but it still works ? |
Pull FUSE 49 front fusebox in cubby and get out ans lock the car. Wait 5 minutes unlock fit the fuse and start the car. May work normally does. |
just make sure there's no gadgets left plugged in and with this nice warm weather it should be ok....might also be worth asking where you park it if they have a jump start facility, just in case.. ... - .- -.
Thanks for the responses |
Just pulled fuse 49 and screen is back on thanks |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Maybe get a solar charger? |
While where at it drivers side rear entertainment screen not working is there a fuse for that ? |
Probably but not sure which.... |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 ![]() ![]() |
Put a charger on it. Ctek MXS 5.0. Works perfect.
I am leaving for 4 weeks and have done so before and it always started first try. So I wouldn't worry about it too much unless you have been having battery problems. If you have it in a garage it is easy to put it on trickle charge then I suggest to do so, just to keep the battery topped up. It may be freezing again when you come back |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
My DB7 had this battery problem, after 2 weeks...dead. Bought a solar charger put it in the cigar lighter and problem gone.
