Home > Technical (L322) > lost / stolen keys
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I don't believe that is completely correct as there is space on the configuration file for keys 3 & 4. I'm not sure if tue technician can disable the old remotes by over writing the key 1 & 2 position but the car will definitely work with more than 2 keys. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #20162 15th Jun 2010 9:17am
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Myunderstanding:
There is space to configure 4 keys but you can alter the functions for each one - anti-hyjack, lights-on etc
They cannot over-write key #1 if it is lost, but they can disable it and add key #3 instead.
Post #20193 15th Jun 2010 12:47pm
Andy
I was told a different story by my local dealer. There are two keys programmed into the car and if one goes missing, you order a new one from the factory, which then replaces either key 1 or 2 depending on which one is missing. Then, the outstanding key will cease to electronically function, although it will manually open a door. If this is done, the alarm will sound. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #20419 17th Jun 2010 12:06pm
Vogue
ah now we are getting somewhere, so Noddy if the Alarm sounds is this just once and then thats it? or would it sound intermittently indeffinitely - I realise you may not know the answer...
reason being lost a key quite a while ago and wondered if somebody could get in without me knowing and lock her up afterwards...
Post #20421 17th Jun 2010 12:39pm
cookie42
2005 Range Rover Vogue Td6 Java Black
this is exactly what i've been told , the alarm will sound constantly and will not start the car or disable the immobiliser
Post #20444 17th Jun 2010 4:05pm
Andy
I'm told it will sound constantly until the usual reset. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #20509 18th Jun 2010 6:57pm
cookie42
after telling me they would take 3 weeks i got my new set of keys today.
hurried home all excited only to find they had ordered the wrong set & sent me 2 keys for someone elses car Banging Head
oh well only another weeks wait for a new set Big Cry
Post #20513 18th Jun 2010 7:18pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I just ordered a new one under warranty for my 2007 (faulty key). They told me 48hrs but it came next day?? How come so long for yours???????????
Also, I had to take my car in so it could be coded??
Post #20514 18th Jun 2010 7:19pm
cookie42
dont know why it takes so long. you can code the keys yourself , have a look here
http://www.fullfatrr.com/forum/topic1623.html?highlight=key
mine has to be coded to remove the old keys
Post #20517 18th Jun 2010 7:25pm
