Home > Maintenance & Mods (L322) > Standard time to repair
tcmnorcal
Ireland 2006 Range Rover Vogue TDV8 Tonga Green
Hi,
Hope someone can help, just moved from a P38 that finally died at 280k miles to a new'ish L322. Never had a problem with the P38 and already day two and the L322 breaks down Evil or Very Mad
So now I'm off to get this fixed and wanted to find out what RangeRover estimate the standard time is do the following two jobs;
Diagnose a faulty alternator
Replace a faulty alternator
By the way this is for the TDV8.
Thanks
Conor
Post #202028 2nd Aug 2013 1:29pm
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Hi, much like you I moved from a very reliable P38 to a TDV8.
Alternator replaced this year. Battery light came on and off sometimes stayed off. Took straight to garage next day as did not want new Land Rover fitted battery ruined as well.
Alternator identified as faulty and replaced. (No charge listed)
Done at trusted main Land Rover dealer. Job was 3.40 hours So labour was £314.50 Alternator was £239.17. So cost was £553.67 + Vat which came to £664.40 all in.
Post #202042 2nd Aug 2013 3:19pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
£650 is what I have been quoted by my local stealer for a new alternator on my TDV8. Mine just has a whine from the bearings, so not getting it done till it fails 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #202048 2nd Aug 2013 3:50pm
Googsy
Conor depends on who you get to do the job who are you planning to use to do the job as I might have some recommendations pm me your number if you want to discuss.
Conor 1 Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #202058 2nd Aug 2013 4:24pm
tcmnorcal
Thanks for the feedback, so far have been quoted €350 in parts which sounds about right but the labour is estimated at 7 hours which just sounds wrong.
Will go back and get them to check their numbers!!!
Thanks
Conor
Post #202071 2nd Aug 2013 5:29pm
Benfelrr
Sounds like they are quoting for the Sport TDV8 which I think is a more complex job beocause of space, body etc.. Others will advise if that is correct or not.
Post #202086 2nd Aug 2013 7:49pm
Mikey
Actual time to replace (in a workshop) is 3-4 hours Thumbs Up
Post #202095 2nd Aug 2013 9:27pm
I seem to remember that £650 all in is about the going rate at a md, little bit less at a indy, its quite an involved job as you have to remove the rh turbocharger aparently which also invlolves removing the starter motor and a cat.
Dunno if there is a "simple" way to do it, but when you look at the amount of stuff to take off first on rave its no wonder its an expensive job......
It is one of the achilles heels of the car, but once done it should be good going forwards (and backwards).
I am waiting for mine to fail at the moment........... Hope it wont do it in france next week, no symptoms as yet though. There is nothing that can't be fixed with a hammer😜😜
Post #202096 2nd Aug 2013 9:34pm
Mikey
No you don't Confused
It's all done from the front. No need to go near the turbo's or exhaust...
Post #202209 3rd Aug 2013 10:18pm
As i said not sure if there is an easy way, thats the way rave says to do it for a tdv8,
Question
Cat off
Starter off
Rhs turbo off
Alternator/generator off.
If there is an easy way then great, should be cheaper! But the MD should do it as per Rave, and price it as such. There is nothing that can't be fixed with a hammer😜😜
Post #202214 3rd Aug 2013 10:59pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Have you done this Mikey? Can you elaborate on how it was done without all the other stuff coming off? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #202229 4th Aug 2013 7:28am
Coz if there is an easy way to do it without removing a whole heap of stuff mine will be coming off on the drive before i go to france!!
I have only not done it cos its appers to be a ramp job with lots of potential problems in other bits of the car if done wrong, im not mne to shirk away from a bit of spannering, but this looks tricky on paper. There is nothing that can't be fixed with a hammer😜😜
Post #202237 4th Aug 2013 9:23am
Mikey
Question
Cat off
Starter off
Rhs turbo off
Have done quite a few Laughing
All done from the front of the engine. Coolant needs drained, fan cowling and fan comes off. Belt comes off, a few coolant hoses need unbolted from the front of the engine.
2 bottom bolts on the alternator are a bit awkward to get to, and its a tight squeeze to get it out of the engine bay, only comes out and goes in 1 way, but easily do-able
I have done plenty of How-To's on the D3 + RRS forum. Maybe it's time I migrate over here for a while Whistle Thumbs Up
Post #202239 4th Aug 2013 9:29am
Just had a look and cant even see it, and ive left my tools at work, so further investigation will have to wait.
Is there any way to tell if failure is imminent, at the moment it is running quietly, and the hidden menu shows 14.5v when running, so looks like its charging ok. So hopefully should be ok for a fortnight.
Richtdv8 said when his went it was a gradual and noisy affair. There is nothing that can't be fixed with a hammer😜😜
Post #202269 4th Aug 2013 11:13am
