![]() | Home > Maintenance & Mods (L322) > Standard time to repair |
tcmnorcal Member Since: 30 May 2013 Location: Dublin Posts: 5 ![]() ![]() ![]() |
Hi,
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
£650 is what I have been quoted by my local stealer for a new alternator on my TDV8. Mine just has a whine from the bearings, so not getting it done till it fails 56 TDV8 Vogue SE
Conor depends on who you get to do the job who are you planning to use to do the job as I might have some recommendations pm me your number if you want to discuss.
Thanks for the feedback, so far have been quoted €350 in parts which sounds about right but the labour is estimated at 7 hours which just sounds wrong.
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
Sounds like they are quoting for the Sport TDV8 which I think is a more complex job beocause of space, body etc.. Others will advise if that is correct or not. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1861 ![]() ![]() |
Actual time to replace (in a workshop) is 3-4 hours |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
I seem to remember that £650 all in is about the going rate at a md, little bit less at a indy, its quite an involved job as you have to remove the rh turbocharger aparently which also invlolves removing the starter motor and a cat.
No you don't ![]() It's all done from the front. No need to go near the turbo's or exhaust... |
As i said not sure if there is an easy way, thats the way rave says to do it for a tdv8,
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Have you done this Mikey? Can you elaborate on how it was done without all the other stuff coming off? My Previous RR's! 2018 P400e Autobiography 2008 TDV8 Vogue 2006 TD6 Vogue 2007 TDV8 Vogue 2007 RRS (I know, it doesn't count!) 2005 4.4 Vogue on LPG 2005 TD6 Vogue 2003 4.4 Vogue 2001 4.6 HSE 2000 2.5 DHSE 1999 4.6 HSE 1997 4.6 HSE on LPG 1995 2.5 DSE 1989 3.9 EFI classic 1988 3.5 EFI classic |
Coz if there is an easy way to do it without removing a whole heap of stuff mine will be coming off on the drive before i go to france!!
Have done quite a few ![]() All done from the front of the engine. Coolant needs drained, fan cowling and fan comes off. Belt comes off, a few coolant hoses need unbolted from the front of the engine. 2 bottom bolts on the alternator are a bit awkward to get to, and its a tight squeeze to get it out of the engine bay, only comes out and goes in 1 way, but easily do-able I have done plenty of How-To's on the D3 + RRS forum. Maybe it's time I migrate over here for a while ![]() ![]() |
Just had a look and cant even see it, and ive left my tools at work, so further investigation will have to wait.
