Home > Technical (L322) > Air Conditioning Service with LPG installed?
Page 2 of 3 <123>
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
no I dont. would it be useful in diagnosing what the feck is going on with my air con?
Post #200367 23rd Jul 2013 9:43pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Its what I used to diagnose the same problem I had - cold LHS warm RHS, lots of people told me "If you have some cold air then it cant be low gas"
A check on IIDTool told.me the evaporator was at 20-something degrees, after regas it was 3.something and the system now seems almost too powerful if left on max setting.
I know you've had a regas but are you 100% sure it was done correctly, I opted to not go with the qwik-fit general garage approach and went to my local LR specialist independent so I knew it would be done right.
Post #200370 23rd Jul 2013 9:51pm
SoggyBottoms
well I did go to people who are regarded as specialists but the access issue from the lpg plumbing left them as bad as a franchise teapot. As I said it's in for a couple of proper services over the next week and I'll keep updating as we go
so how much is the new BT IIDtool?
Post #200379 23rd Jul 2013 10:19pm
Katash
BT IIDTool not released for general sale yet - maybe a general OBD reader will give you the evaporator temp but I doubt it.
Post #200381 23rd Jul 2013 10:23pm
SoggyBottoms
the saga continues..... still no air con
it went into a local specialist Indie but apparently they don't do air con so took it to a local to them air con place who also couldn't access the LP port and put more gas and dye in there. not cold
again their complaint was they couldn't diagnose coz they can't access the lp port
I posted about my woes on a local 4x4 forum and a specialist air con place was suggested that might be able to replace the pipe with the LP port on with one with a port in a more accessible position, or swage a LP port on.
Took it to him this morning and he looked at it and said Yes he could do the job but didn't understand why I wanted it doing. I said about all the other places saying they can't service or diagnose it without access to the LP port and he said it was a load of tosh and he could get in thru the HP side.
I pointed out that all the others had done this and the b#gger still wasn't cold so I didn't think it was about gassing it up. He offered to have a look on a no fix no fee basis and suggested a local cafe I should disappear to for half an hour.
I returned later and he'd got a reader on the OBD port saying he'd checked the gas and it was slightly overcharged but that he couldn't find any faults. He said he thought it was the compressor and that he didn't think it was running. Fine says I, how do we check? Well he says we could just replace it or you could take it to an auto electrician to check it's getting feeds.
I thank him and wend my pee'd off way back home.
In contact with a few local auto electricians and mention Range Rover and they had too much work, not enough staff etc.
I eventually found an auto electrician that also does air con and the guy that's gonna work on it is a Land Rover enthusiast - that's gonna happen on Friday.
fingers crossed
I guess the bit that surprises me is that someone who offers to service cars to dealer standard doesn't offer dealer level service on the air con? Or am I on the wrong wavelength here?
Would a dealer put the job out also?
Post #202657 6th Aug 2013 4:03pm
Katash
Its pretty easy to tell if the compressor is running - you will hear the clutch engage and dis-engage when you turn the system on/off and mine kicks on/off under normal running.
Post #202659 6th Aug 2013 4:31pm
SoggyBottoms
I'll have another butchers tomorrow.
It's on charge now after today's hijinks of these guys leaving doors open while they go off to do other stuff, fans running but not the engine etc
I was thinking "I'm gonna need a jump if they feck about much longer"
Post #202661 6th Aug 2013 5:03pm
SoggyBottoms
I had a couple of hours going thru RAVE yesterday so I'm in more informed position.
I also found this site http://www.agcoauto.com/content/View_by_Category
there is so much valuable info there perhaps it should be in the Wiki?
http://www.agcoauto.com/content/news/p2_articleid/210 how air con works
http://www.agcoauto.com/content/news/p2_articleid/256 diagnosis pt1 electrics
http://www.agcoauto.com/content/news/p2_articleid/257 diagnosis pt2 understanding the test gauge readings
http://www.agcoauto.com/content/news/p2_articleid/258 diagnosis pt3 leaks
http://www.agcoauto.com/content/news/p2_articleid/259 prevention
reading thru these demonstrates how access to the LP port appears to be vital to accurate diagnosis - so all these monkeys just draining my system and topping it up are doing feck all to actually address the issue [insert unhappy bunny emoticon] Wink
Post #202808 7th Aug 2013 2:00pm
Katash
Soggy - do you have TOPIX? Its much more relevant to your MY
Post #202818 7th Aug 2013 2:51pm
SoggyBottoms
thought that was trade only?
anyway I have this http://www.fullfatrr.com/forum/topic17623.html which appears to definately be for my 2007MY
Post #202829 7th Aug 2013 5:13pm
Katash
Yes that contains the data from Topix
Post #202831 7th Aug 2013 5:21pm
SoggyBottoms
still not fixed. access to LP port sorted, no sign of pressure loss or leakage; but still no cold.
no faults showing so now he's thinking do it the old school way and test each individual component
Post #206009 27th Aug 2013 9:11pm
cass
Did you confirm that the LPG hot water routing was correct ?
You could check this by clamping the hot water hose either into or out of the vaporiser then check the temperatures while running on petrol - it's worth a go as it costs nowt
Post #206135 28th Aug 2013 3:17pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I had the same problem when I converted my SC to LPG . I had inadvertently plumbed in the water to return in to the wrong hose. This bypassed one of the water valves and allowed hot air to be blown through the right hand face vent and cold air to the left.
The flow and return hoses for your vaporiser should be tee'd into heater hoses at the rear of the engine on the drivers side.
Worth checking just in case they have been incorrectly connected.
Stewart.
Post #206232 28th Aug 2013 8:37pm
SoggyBottoms
sorry Cass, I should have said - this is a new issue.
I've had the car a year with no air con problems until this happened and the lpg was recently service by Autotech up Derby way who are seriously competent and gave me loads of advice on the Rangie
seriously thinking about getting the iid tool as that appears to allow hevac testing and I suspect it would be allround useful anyway
7. Control I/O
Definition
The Control Input and Output menu allows testing individual components of a system. For example:
• Output: Activating a suspension valve.
• Input: Simulating an input value coming from the cabin temperature sensor to verify part of the
HVAC system functionality.
Post #206252 28th Aug 2013 9:35pm
Page 2 of 3 <123>
