![]() | Home > Maintenance & Mods (L322) > Rust Repairs - Wax Oiling an 'Extra' ? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I cant think that these areas would be routinely waxoiled, that woukd generally be reserved for the underside of the car.
Hi, found reference to the wax oil query on the below thread. Baron had said that his warranty repairer said that they are instructed by LR to spray waxoil inside the bottom of the door to stop the same happening again. He removed his door trim to check and his had been done. Hoppy_70 said similar on the same thread. Hence I asked the MD if they had wax oiled mine, only to be told they had not.
I would imagine they have repaired it per original spec, which wasnt waxoiled.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Ide waxoil them but make sure the drain holes are not filled in the process |
Thanks all/ Craig... how is it done please... I take it no panels need taken to bits to do it and it's just a case of injecting the wax oil in the holes (layman's description)?
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Yep, waxoiling will certainly stop any internal rusting from forming and external too with occasional reapplication. What I was told by the Aberdeen local approved LR body repairer Kinghorn was that they are instructed to inject waxoil into any newly fitted upper tailgate. They did mine as I checked. 4.4 TDV8 Vogue Baltic Blue MY11 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
I would have pushed to have the tailgate replaced personally, given its such a widely known issue |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
There is something in the Workshop Manual about corrosion and that anyone reprinting the car should 'be familiar with corrosion protection used on this vehicle.' If they're being difficult, will they guarantee their NEW parts with a full, new corrosion warranty? I think they'd rather waxoyl it. |
