Home > Technical (L322) > Suspension fault- front left sensor vs self lowering
andrzjb
2007 Range Rover Vogue TDV8 Java Black
Hi
Simple question
does faulty level sensor in front left area could cause suspension lowering after some time left
When I drive except "suspension fault" on the dashboard all is ok, lowering etc works ok.
when I left the car (key to the pocket) suspension left on the last postion
After some hours in parking (garage) car is lowering to lowest level
is it normal during "sensor" faulty condition?
rgds
Andrew
Post #202850 7th Aug 2013 6:55pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
The standard test would be to raise the suspension to off road height (the highest setting). If after 12-24 hours one corner lowers, then it is either the airbag on that corner leaking or a leaking pipe.
Then you should spray soapy water around the airbag to check for a leak.
I had one of the very rare cases of a leaking pipe rather than an airbag!
Post #202887 7th Aug 2013 10:47pm
andrzjb
After night with open door(battery charger pluged) all car lowered
How about that? As I said I have faulty left front sensor (faults checked by diagnostic soft)
IT could be conected?
Post #202900 8th Aug 2013 5:09am
andrzjb
All car lowered however both front more
Post #202902 8th Aug 2013 5:19am
Possibly.....but more likely you have a leak somewhere.Stick on Off Road height and do the soapy water or listening test.
You may need to put your back to the wheelarch and lift with your legs to get airbag up a bit more for leak to show itself.
If you eliminate the bags then you will next need to look at the cross over valves (behind inner wings) and reservoir (under cover) for leaks on connections, then to the compressor. .
Post #202973 8th Aug 2013 6:17pm
