Home > Technical (L322) > Hmmmm crunching sounds
Mustard
When I put my rr into low range mode, engage Hill decent control and the drive it forward it starts making some horrible crunching type sounds which I can also lightly feel through the steering wheel. If i disengage HDC and continue in a forward motion it is smooth and nice. Anybody any ideas what this may be please ?
Post #204464 16th Aug 2013 11:45pm
Dolphinboy
just a hunch but I think it's your ABS system operating on the wheels for controlling the descent rate. You normally only use this on a down hill. Perhaps if you are using it on the level the system cant feel it going fwd adn so activates the system.
As I say, knowing the system and without seeing or hearing it myself, I would think it is this.
Alternatively it could be your low range not engaging fully (there is a lot of info here on this - use search, your friend)
Post #204467 17th Aug 2013 12:02am
Mustard
Ok Ill get it on a decent slope and try again. I have had it going downhill on a steep but short decline not so long ago with zero issues. As well as it being my own personal roller coaster in slow motion there was no crunching sounds then Smile
Just as a side note we tried the same operation 'on level ground' in my friends rr sport and there was no crunching sounds, just nice and smooth Question
Post #204473 17th Aug 2013 12:14am
Martin
Site Admin
HDC does indeed crunch Smile
Post #204474 17th Aug 2013 12:28am
Its the HDC!!!
Thats what it does. Discovery 4 HSE
Post #204487 17th Aug 2013 8:23am
Mikey
HDC works completely differently when there is plenty of grip Thumbs Up
When there is little grip, the HDC comes into it own
Post #204496 17th Aug 2013 10:14am
Mustard
so I am correct in assuming that the HDC crunching away on level ground is normal ? Or indeed just crunching away is normal ? Im a little paranoid here as I dont like the noise / feeling it is doing
Post #204505 17th Aug 2013 11:25am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I used it downhill on a steep Tarmac slope... It is a very weird noise indeed... Crunchy Laughing Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #204507 17th Aug 2013 11:45am
Mustard
Ok so I tested the HDC on a serious decline tarmac track, it sure made its crunchy sounds to begin with but then they went away and the rr drove me down the hill as it saw fit, very nice Thumbs Up
I pressed the go faster pedal and the crunchy noises began again and got worse as i lifted off the pedal then went away so this leads me to ask the question are you meant to press the accelerator when your in HDC low range mode or just leave it to drive itself ?
Post #204704 18th Aug 2013 9:45pm
supershuttle
Mine works like this, the crunching seems to happen when you use the accelerator. I think HDC is for situations where you wouldn't use the accelerator it's for going down very steep slopes safely, I find just engage it and leave it to the car - no brake no accelerator, still a bit of racket as I think it uses the ABS in some way. Geoff
Post #204737 19th Aug 2013 9:40am
Dont use the accelerator with hdc engaged, it is for descending slopes at a constant rate and that is about walkimg pace. This is regulated by the car.
When descending a steep slope, activate hdc and take feet off both pedals.
Try to go faster and the abs is activated......
Methinks. There is nothing that can't be fixed with a hammer😜😜
Post #204840 19th Aug 2013 10:13pm
i'm sure it explains that in the manual.. ... - .- -.
Post #204866 20th Aug 2013 8:39am
HDC should be thought of as like an extreme ABS that does the work for you , approach steep decent , engage HDC and descend hill with feet away from the pedals and disengage at the bottom . You can adjust your speed with the cruise control up and down buttons but I can't remember when this was introduced . 2008 MY Supercharged
Post #204869 20th Aug 2013 8:51am
