Home > Technical (L322) > Hmmmm crunching sounds |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
just a hunch but I think it's your ABS system operating on the wheels for controlling the descent rate. You normally only use this on a down hill. Perhaps if you are using it on the level the system cant feel it going fwd adn so activates the system.
17th Aug 2013 12:02am |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
Ok Ill get it on a decent slope and try again. I have had it going downhill on a steep but short decline not so long ago with zero issues. As well as it being my own personal roller coaster in slow motion there was no crunching sounds then
17th Aug 2013 12:14am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
HDC does indeed crunch |
17th Aug 2013 12:28am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
Its the HDC!!!
17th Aug 2013 8:23am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1694 |
HDC works completely differently when there is plenty of grip When there is little grip, the HDC comes into it own |
17th Aug 2013 10:14am |
so I am correct in assuming that the HDC crunching away on level ground is normal ? Or indeed just crunching away is normal ? Im a little paranoid here as I dont like the noise / feeling it is doing |
17th Aug 2013 11:25am |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
I used it downhill on a steep Tarmac slope... It is a very weird noise indeed... Crunchy Alcohol and eBay is never a good mix
17th Aug 2013 11:45am |
Ok so I tested the HDC on a serious decline tarmac track, it sure made its crunchy sounds to begin with but then they went away and the rr drove me down the hill as it saw fit, very nice
18th Aug 2013 9:45pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3650 |
Mine works like this, the crunching seems to happen when you use the accelerator. I think HDC is for situations where you wouldn't use the accelerator it's for going down very steep slopes safely, I find just engage it and leave it to the car - no brake no accelerator, still a bit of racket as I think it uses the ABS in some way. Geoff |
19th Aug 2013 9:40am |
Dont use the accelerator with hdc engaged, it is for descending slopes at a constant rate and that is about walkimg pace. This is regulated by the car.
19th Aug 2013 10:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34928 |
+1
20th Aug 2013 8:39am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
HDC should be thought of as like an extreme ABS that does the work for you , approach steep decent , engage HDC and descend hill with feet away from the pedals and disengage at the bottom . You can adjust your speed with the cruise control up and down buttons but I can't remember when this was introduced . 2008 MY Supercharged
20th Aug 2013 8:51am |
