![]() | Home > General > Got an hour to kill! |
Front end first? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
LR Assistance have just been and apparently the starter motor is knackered so it's going to the dealer in the morning |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
"lack of use"..!! In that case the starter should be like new... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
sounds like the battery to me .... ... - .- -.
When you push the button everything lights up normally and you get a metallic click from the solenoid on the starter motor. it'll do it a few times and then usually start. When it does start it fires instantly and turns over as normal.
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
starter motors are a two stage operation..
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Had precisely the same symptoms on my 4.4 tdv8 at only 4500 miles. Dealer replaced starter motor, no problems since. Agueroooooooooo. 93-20
I know how the starters work as I've rebuilt several of them over the years, quite interesting bits of kit in some ways.
Well after two days of hearing nothing from the dealer I rang them today to find out what was going on with the car.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 926 ![]() ![]() |
Interesting. My vehicle just had the starter motor replaced on the 4.4TDV8 engine.
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Hmm, I bloomin' hope not!
33k |
4500 miles.
