![]() | Home > Maintenance & Mods (L322) > Colour coding SC Grill and vents |
See my gallery I had mine coded the newest style vents as fitted to mine will fit all years. Present :2008 TDV8 HSE
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Really like this. Saw a rimini red with black vents, badges and wheels....bit blingy but looked |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
Supershuttle - I like that.
Conor's whistle is that he thinks I should get the front replaced with all the 2011 LEDs etc. I got the work done locally and I did take the bits off, probably why I didn't have the door handles done - too much work , I haven't mentioned the rear spoiler but that was my fault |
No I meant that you are going to colour code the grille just a matter of time |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6375 ![]() ![]() ![]() |
I colour coded my front grille recently, love the look, vents will be next.
I like the coded vents but have seen one with satin / gloss black on the vents, grill and handles.... |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 235 ![]() ![]() ![]() |
Both the grill and side vents are easy to remove so you could just drop the parts off at a local body shop and stay on the road. If you wanted to keep the cost down, perhaps you could even do some of the prep work yourself, masking off the mesh parts, flatting down the plastic with wet and dry and maybe even priming the parts. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
For the best results you need to take the grills apart before painting so they do not peel from a masked edge... The side vents just unclip/unscrew but the front grills are plastic welded together so will need leavering apart and bonding back together after painting |
Craig,
I think its best when the SC grille surround matches the body colour but i am biased and was lucky mine was already a very close-ish match |
Geoff, I still on holiday my friend ![]() ![]() |
