Home > Maintenance & Mods (L322) > Holy crap!
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Holy crap!
So this was my near side ball joint. LITERALLY fused into the hub. I actually thought it might have been welded at one point... Lump hammer/ cold chisel/ many many hits later =
 My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #205778 26th Aug 2013 3:41pm
They're often like that to come out
Post #205779 26th Aug 2013 3:46pm
mpirie
Ah, that'll be fine, it'll polish out Whistle
Post #205796 26th Aug 2013 5:38pm
paneldamage
I had same experience : it's better for access to wack it squarely when you take the hub off totally. This is actually an easier option IMHO, when the balljoint is totally seized into the housing. Course, you wil then find that the stub shaft is rusted into the splined section, preventing that approach. Nor sure why manufacturer doesn't use anti- seize ( copper grease) on assembly.....
Post #205833 26th Aug 2013 9:27pm
Because that would cost an extra 10p per vehicle on production costs Whistle
Post #205835 26th Aug 2013 9:32pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
We're having the same problem with my rear balljoints. Offside upper and lower have been done. Near side upper had to be cutout with a hacksaw. Going to tackle the lower near side this weekend. Ordered a new camber bolt for the one we need to cut through.
Post #205842 26th Aug 2013 10:05pm
hoppy_70
Separating the lower one from the hub was also a pig. Used a technique shared on here involving putting a big spanner in the gap then jacking the spanner up! It's a satisfying ping when it pops!
After changing the one above mine still has a little creak!
Arrrrrgghhhhh Question Censored Censored Censored My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #205999 27th Aug 2013 8:37pm
