Home > Maintenance & Mods (L322) > URGENT.....help needed to release rear brake disc.
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
can any one explain PLEASE on how to release rear brake disc.
it is a 2007 RR with electric hand brake .
i cannot seam to find this 'clicking wheel' that releases the hand brake shoes.
i have removed the inspection cover and positioned it at the 11oclock position...
ahhhhhhhh.
thanks 2011 4.4 TdV8 Nara Bronze
Post #205761 26th Aug 2013 9:56am
goldsax
warning...
do not try to change the discs at home unless you have the software to put the electronic hand brake into service mode!!!! 2011 4.4 TdV8 Nara Bronze
Post #205895 27th Aug 2013 11:00am
wealy
The inspection hole needs to be at 6 O'clock.
The adjuster is easy to feel through the hole with the plug removed.
Post #205954 27th Aug 2013 4:58pm
There is also an emergency release near the shifter if I'm correct Whistle
Post #205993 27th Aug 2013 8:16pm
paneldamage
Yeah, adjuster is at 6 o clock, but it's a bit fiddly if you have never done one before. When I changed mine, I didn't set Service Mode on the EPB and it was all fine. FYI, I understand that if you accidentally apply the EPB without the park brake shoes etc connected and the disc fitted, it will destroy the EPB module at £ 400 a pop.....
Post #206027 27th Aug 2013 11:05pm
goldsax
so is the release at the 6 oclock positon a clicking rotor type where you put a screw driver in and rotate the teeth? 2011 4.4 TdV8 Nara Bronze
Post #206118 28th Aug 2013 1:35pm
yes that the puppy.
the emergency release is in the boot, in the RSH cubby, little loop of wire.
Couldnt figure out what it was, pretty sure its the EPB release though. There is nothing that can't be fixed with a hammer😜😜
Post #206219 28th Aug 2013 7:25pm
^ Is that not fuel door release? (not certain)
Post #206223 28th Aug 2013 7:35pm
Googsy
I think thats the fuel release too. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #206231 28th Aug 2013 8:32pm
nope, deffo epb release, just looked on rave. There is nothing that can't be fixed with a hammer😜😜
Post #206235 28th Aug 2013 8:55pm
Well that's a good RR FACT!
Post #206261 28th Aug 2013 9:47pm
Ahh, on the sport it's under the shifter... Sorry sir Bow down
Post #206262 28th Aug 2013 9:48pm
goldsax
northernmonkeyjones wrote:
yes that the puppy.
thanks for the info...
when pulled this manually releases the EPB.
is there a procedure to reset the EPB after disc replacement?
sorry but RSH means? ( simply put..the drivers side or passenger side boot cubby?)
many thanks 2011 4.4 TdV8 Nara Bronze
Post #206297 28th Aug 2013 10:29pm
Drivers side cubby.
I did post up how to reset the epb the other day.
http://www.fullfatrr.com/forum/topic19932-15.html There is nothing that can't be fixed with a hammer😜😜
Post #206328 29th Aug 2013 7:33am
