![]() | Home > Maintenance & Mods (L322) > URGENT.....help needed to release rear brake disc. |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
warning...
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
The inspection hole needs to be at 6 O'clock.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
There is also an emergency release near the shifter if I'm correct |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Yeah, adjuster is at 6 o clock, but it's a bit fiddly if you have never done one before. When I changed mine, I didn't set Service Mode on the EPB and it was all fine. FYI, I understand that if you accidentally apply the EPB without the park brake shoes etc connected and the disc fitted, it will destroy the EPB module at £ 400 a pop..... |
so is the release at the 6 oclock positon a clicking rotor type where you put a screw driver in and rotate the teeth? 2011 4.4 TdV8 Nara Bronze |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
yes that the puppy.
^ Is that not fuel door release? (not certain) |
I think thats the fuel release too. Present :2008 TDV8 HSE
nope, deffo epb release, just looked on rave. There is nothing that can't be fixed with a hammer😜😜
Well that's a good RR FACT! |
Ahh, on the sport it's under the shifter... Sorry sir |
thanks for the info... when pulled this manually releases the EPB. is there a procedure to reset the EPB after disc replacement? sorry but RSH means? ( simply put..the drivers side or passenger side boot cubby?) many thanks 2011 4.4 TdV8 Nara Bronze |
Drivers side cubby.
