![]() | Home > Technical (L322) > Air Conditioning Service with LPG installed? |
I'll put a £10 bet on the hevac playing up |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
so today my IIDTool arrived and I went outside to play with it
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Supprised the 'experts' didnt find that - glad you narrowed it down |
It could be a connector or wiring indeed, worth a check. Also you can take the connector of and see if the coupling can be activated externally by putting 12V on it directly.
cheers for that |
Nope, now you just need to find a good Indy that can do the work for you or get your hands dirty. No clue what the clutches go for but Dan can probably give you a quick price |
this linky has been posted before so that's a compressor for £310.58 unless anyone knows anywhere cheaper? or there's a reason not to use this source or product?
