![]() | Home > Technical (L322) > Titanium Trim Piece replacement |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
As far as I know it's either some simple clips or adhesive. When your new one arrives you'll be able to see how it goes on, not rocket science I bet. Discovery 4 HSE
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I think Mick will tell you differently! Current MY2020
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
There are about 12 little 'tongues' that slot through the backing bumper, these have a tooth type end that holds the trim on, difficult to remove from the front, as Mick knows, but straightforward if you take the bumper off and release the tongues one by one, starting at one end. |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 391 ![]() ![]() |
Thank you! I don't think I will be removing the bumper but can you see then from underneath the car? Mike |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
I took my titanium silver one to replace it with a black one while the bumper was off.
Removing the front bumper in that case is not very hard, I did it on my last one, its actually held on by about 10 screws. Discovery 4 HSE
Hi , sorry been away from laptop for a few days, I am pretty sure you can't get to the back of he trim piece...if
Watch a video on taking Bumper Off really quite easy and ten minutes. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Removing the strip is a PITA job with the bumper on... |
Hi, Where can i find a video showing how to remove the front bumper? I googled it and nothing came up. Thx! Mike |
I assumed there would be a video like the one for the rear bumper.
If you have a friend to help you makes it easier , lying underneath the front of the car you will see where the rim of the splitter bar starts ……
I think spraying the bar in BMW Titanium Silver would be easier! |
PITA masking off area around it tho … if you want a pro look |
