Home > Technical (L322) > Folding mirror dilemma
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Mirrors have suddenly stopped folding in when the door top button is pressed. They fold back and when they reach the window immediately open again.
The garage reckons this is a fault with one of the motors but I'm not so sure. Has anyone else had this problem?
Big Cry 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #207767 3rd Sep 2013 7:29pm
Battery reset is your first step my friend... Could well be a motor though Rolling Eyes
Post #207768 3rd Sep 2013 7:34pm
It'll probably be the microswitch. They get bent, don't make, and send the mirrors back out again. Here is a link to joe90's post...
http://www.fullfatrr.com/gallery/thumbnails.php?album=341 Previously..
Post #207770 3rd Sep 2013 7:41pm
Rich86
Ok thanks. Will take a look and see if I can find the problem... 2009 Vogue TDV8 Nara Bronze
Post #207854 4th Sep 2013 7:22am
ebajema
It can also happen that someone pushed one mirror in or out by hand causing it to lose the home position. Happens with mine sometimes when the mechanics have worked on the car. Battery reset seems to cure it. MY 2010 5.0 SC Galway green and sand interior!!
Post #207855 4th Sep 2013 7:26am
Or check wiki for other solutions, double pressing button quickly etc. There is a lock out if you do it too much. .
Post #207942 4th Sep 2013 1:55pm
Rich86
Does anyone have any tips on how to remove the upper trim around the window as I am going to replace the door mirror?
I can see the trim probably clips on and off and that the mirror is held on with 3 main bolts, however, does anyone know whether the two wired plugs that the mirror has are above or below the window line? If they are below then obviously I will need to remove the door panel which I want to avoid.
Thanks... 2009 Vogue TDV8 Nara Bronze
Post #208861 8th Sep 2013 1:55pm
mjdronfield
Not sure if this helps.
Sounds like you may have got this far already ;
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #208877 8th Sep 2013 2:57pm
Rich86
There's a video on YouTube too but I'm unsure whether the door air bag would be disturbed.
The rubber bung marked airbag...is this just a bung tha comes out to access a screw to undo the door panel does anyone know? 2009 Vogue TDV8 Nara Bronze
Post #208880 8th Sep 2013 3:07pm
mjdronfield
Take the bung out, its just a cover. There is a fairly large philips screw behind it.
Removed the door card a few times on my mates 4.4 V8......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #208883 8th Sep 2013 3:19pm
