Home > Technical (L322) > Folding mirror dilemma |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Battery reset is your first step my friend... Could well be a motor though |
3rd Sep 2013 8:34pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
It'll probably be the microswitch. They get bent, don't make, and send the mirrors back out again. Here is a link to joe90's post...
3rd Sep 2013 8:41pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Ok thanks. Will take a look and see if I can find the problem... 2009 Vogue TDV8 Nara Bronze
4th Sep 2013 8:22am |
It can also happen that someone pushed one mirror in or out by hand causing it to lose the home position. Happens with mine sometimes when the mechanics have worked on the car. Battery reset seems to cure it. MY 2010 5.0 SC Galway green and sand interior!!
4th Sep 2013 8:26am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Or check wiki for other solutions, double pressing button quickly etc. There is a lock out if you do it too much. .
4th Sep 2013 2:55pm |
Does anyone have any tips on how to remove the upper trim around the window as I am going to replace the door mirror?
8th Sep 2013 2:55pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7646 |
Not sure if this helps.
8th Sep 2013 3:57pm |
There's a video on YouTube too but I'm unsure whether the door air bag would be disturbed.
8th Sep 2013 4:07pm |
Take the bung out, its just a cover. There is a fairly large philips screw behind it.
8th Sep 2013 4:19pm |
