![]() | Home > Technical (L322) > [SOLVED] "Coolant Level Low" - NOT! |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
How much are the coolant tanks? |
Not too expensive from memory... PM Dan for an accurate price, but im sure its less than £50 |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Many thanks for your technical advice Craig, I'll swap this out too when I do the radiator at the end of the month. Also tempted to leave the viscous fan off over the winter and see how that goes... .
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
What's the problem with the tanks then? Do they leak or something? |
| NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136
Tanks can crack and then leak - mine did, same on earlier Disco. Easy fix.
Nice find normanp
I can understand it if coolant was low (due to my leak in the rad) but not when coolant level is correct, Perhaps it is a pressure thing too, and/or the coolant sensor being defective? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Changed out my coolant tank today. nothing wrong with the tank itself, and I can now see you can simply change the sensor, part number PCJ000020, Now have a spare tank |
^ Can you do a brief post on "How To" replace the sensor? |
No problem, coming soon... .
These things are great for the WIKI and search |
Done
Have applied a SOLVED to the OP.
| All times are GMT |
