Home > Technical (L322) > Oil leak 57 tdv8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
i suspect it could be some overfill for the oil change running down the engine block.. ... - .- -.
8th Sep 2013 2:51pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
Thanks for such a fast response but the oil is on the second red marker not up to the red ball, I was charged for 9 ltrs of 5/30 fully syn. |
8th Sep 2013 3:04pm |
Queried a minor leak or leaks and a smouldering/hot oil smell with my main dealer for months and was assured all was in order, including the prospect of overfill/ excess oil left over from main dealer servicing work. It could be exactly that with yours or maybe something else.
8th Sep 2013 3:07pm |
Yes this is so bad it will need to be recovered but I cant see on top of the box whats let go, mine has the zf 6 speed auto in it & I wonder if its a cooler pipe split but not easy lieing on your back & you cant see down the back of the engine from the top |
8th Sep 2013 3:14pm |
I would add it looks like engine oil though |
8th Sep 2013 3:15pm |
In our case the specialist identified at least 3 different sources of leak by inspecting the car from underneath on a ramp but he said that the only way to confirm matters was to strip down, for example, removing engine components to determine the actual source of the 'engine oil leak'... And so the car went back to the main dealer for further inspection and repair. |
8th Sep 2013 4:17pm |
I am very lucky or unlucky depending on how you look at it. The oil filter housing which is also part of the oil cooler which sits in the "V" has at some time in the past been repaired with silicone. I doubt the main dealer would have done this given the amount of effort required to strip it out & at only £206 + Vat for the part I would guess the independent who has performed the last three services has a guilty conscience!! So it should be back on the road for the weekend. |
9th Sep 2013 8:08pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
I've got a 57 Tdv8 had the same. Went in for Rear diff leak, found cv joint leak. Walked out lighter of cash but fixed and under warranty. |
9th Sep 2013 8:53pm |
Have now replaced the oil filter/cooler housing in the middle of the V & all nice & dry. Took about 8hrs to do & needed a few extra seals & o rings as the egr ones were a bit manky but all done now. Hope it will be oil tight for a while now lol |
13th Sep 2013 11:37pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Did you find out why it only leaked in D or R? |
14th Sep 2013 10:40am |
I can only put it down to an increase in oil pressure or vibration |
14th Sep 2013 2:02pm |
