Home > Maintenance & Mods (L322) > Door lock problems
paneldamage
Door lock problems
Hi All, hope you can help, got my S/C back from the paint shop now and rebuilding the doors etc that I stripped for the painters. All going well, but having rebuilt all doors, found that the locking mechs on both front doors are not operating. Not from the key, or the dash switch, or remote. The back pair are fine. Also, the one shot function has stopped on all but the down operation of the drivers door. The locks are not putting the interior lights on either, when you open the door. Everything worked fine before.... Any ideas? I have tried a battery disconnect/ reset. Tried cleaning/ remaking the big plug connection on each door pillar, the door lock actuator connector, they seem fine. The IID tool is not showing any faults on the Body Control module.
If it was just one lock, I would think it had gone faulty, but both off at same time makes me think its a module or something else ?
Thanks in Advance, Les
Post #208976 8th Sep 2013 10:08pm
i would suspect the connections . ... - .- -.
Post #208994 9th Sep 2013 7:21am
ebajema
What Stan says. I had my door handles replaced for new ones and one door didn't work "properly" some of the functions worked and some didn't.
I removed the door card and found the connectors were in but not properly seated. So I made sure they did and all the functions were working again. I suggest that you try the same and maybe also check if all the contact surfaces are clean. MY 2010 5.0 SC Galway green and sand interior!!
Post #209000 9th Sep 2013 7:52am
plumajp
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
have you made sure the bar from the lock barrel is fitted into the lock mech?
I left mine out and the i couldnt open the door with the key.
Post #209313 10th Sep 2013 11:44am
paneldamage
Got the drivers door working tonight, cleaned all the connectors with contact spray and the drivers lock is working. Will try the same on the passenger door tomorrow, fingers crossed. The electric windows are still playing up, can any body tell me if the one - shot function is operated by the door module or is controlled by the body module? I guess it's in the body module as there are no door modules on the rear doors.... I have lost some faith with the iid tool, it doesn't show any faults on any of the units. Thanks for all replies, Les
Post #209449 10th Sep 2013 10:04pm
Have you enabled one shot for all the windows with all of your keys ? 2008 MY Supercharged
Post #209464 11th Sep 2013 6:08am
T24RES
Is there a reset procedure for one touch windows once the battery has been disconnected? Certainly is on my other cars. Like holding the button down for a period if time after the window is fully down. Can't remember for the FF.
@Axle - what's an ugly kid widow? Smile
http://www.fullfatrr.com/forum/post140224.html
Post #209521 11th Sep 2013 10:45am
i would have a read of the windows section in the workshop manual ... ... - .- -.
Post #209527 11th Sep 2013 10:59am
paneldamage
For future reference, this turned out to be a loose pin in the white connector going to the door outstation on the passenger side. Took me about four blinking hours to find it, had it in and out a few times, it looked perfect but was not staying in the holder when I pushed it home. To make it worse, it wAsnt throwing any immediate signs of being loose, eg flickering interior lights etc, and nothing coming up on the iid tool. I find that strange, as I would have thought it should have thrown a dtc for lack of door outstation or lost connection to lock , but nothing.
Worth thinking about, I removed the door modules from the door cards while I was messing about looking for the fault, obvious point I know, but worth it as you can then plug the connections back in without trying to manhandle the door card, which seem to have a life of their own.
Post #211851 23rd Sep 2013 8:56pm
paneldamage
One other thing I forgot to mention, the one shot function can be turned off per window in the CCF, I think that's what Axle refers to. Useful to know for anybody looking at this post in time to come, trying to sussed out why theirs might not be working.
Post #211852 23rd Sep 2013 9:00pm
