![]() | Home > Technical (L322) > Lock diff or not on 4.4TVD8 |
If you have the lock symbol on the screen then the locking diff is fitted. It is normally showing an open symbol which changes to a closed lock when the diff lock engages. It is automatic and operates when needed. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Is FFRR different to D3/4 in that respect then? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
on the 3.6 the locking rear diff is shown, but it does not really indicate it is fitted, Mine hasnt got one (i know cos i looked) the locking function is carried out in some form by the traction control. There is nothing that can't be fixed with a hammer😜😜
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I thought the locking rear was just on the SC? |
It was and still is an option i think for most models.
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 ![]() ![]() |
Here the pictures where you see the rear diff as lockable on the navi screen and not on the speedo screen.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
maybe the large tv screen shows the status of both all the time and the smaller dash screen only shows the rear diff status when its active.. ... - .- -.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
My speedo screen shows both the central and rear diffs and both go in and out of lock in bad conditions.
If it's the same as the D3/4 (and I would assume it is), then the presence of the unlocked padlock symbol on the rear diff is NOT indicative that you have a locking rear diff fitted.
