![]() | Home > Technical (L322) > Odd behaviour from Deployable side steps |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Let them first check all the connections, wires and switches. Then make sure the latest software is installed and then use it again for a while.
| Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305
Mine do exactly the same. I wondered too but as it doesn't cause me a problem have decided to let them play. |
Mine too |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Can you change a wheel when you have these deployable steps on .... |
Got to unscrew 4 allen screws to remove a step to provide access to the jacking point. A faff but no big deal. Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
The book says for the step to be removed before jacking... |
| xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274
Mine do the same thing & have done for years so I just ignore them & let them get on with it. |
| Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300
I've jacked mine up with sidesteps using a bottle jack. I locked the steps in the deployed position (or just leave the door on the latch). The jack fits in the point fine. The only slight problem is you don't get a lot of space to pump the jack handle up and down. It does work however. |
| RXWRR Member Since: 30 Jul 2013 Location: Staffordshire Posts: 60
Spoke with dealer today and suggested it may be a loose connection/wiring issue... Response was "it's a new one on them, never heard of this happening before" |
| All times are GMT |
