![]() | Home > Technical (L322) > Odd behaviour from Deployable side steps |
Let them first check all the connections, wires and switches. Then make sure the latest software is installed and then use it again for a while.
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Mine do exactly the same. I wondered too but as it doesn't cause me a problem have decided to let them play. |
Mine too |
Can you change a wheel when you have these deployable steps on .... |
Got to unscrew 4 allen screws to remove a step to provide access to the jacking point. A faff but no big deal. 4.4 TDV8 Vogue Baltic Blue MY11 |
The book says for the step to be removed before jacking... |
xjsracer44 Member Since: 30 Nov 2010 Location: Hertfordshire Posts: 274 ![]() ![]() ![]() |
Mine do the same thing & have done for years so I just ignore them & let them get on with it. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I've jacked mine up with sidesteps using a bottle jack. I locked the steps in the deployed position (or just leave the door on the latch). The jack fits in the point fine. The only slight problem is you don't get a lot of space to pump the jack handle up and down. It does work however. |
RXWRR Member Since: 30 Jul 2013 Location: Staffordshire Posts: 60 ![]() ![]() ![]() |
Spoke with dealer today and suggested it may be a loose connection/wiring issue... Response was "it's a new one on them, never heard of this happening before" |
