|  | Home > Maintenance & Mods (L322) > DRL's again ... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | the reason the police used to stop peeps with fogs on during the day was because the 55 watt power blinding on-coming traffic..replacing these with low power led bulbs for drl purposes is a logical step..
|  12th Sep 2013 9:18am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | so how does one regard golfs with their main beams on low power, or porsches[?] with what looks like lower fogs on... ... - .- -.
|  12th Sep 2013 9:26am |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839      | I used my IIDTool to set the main beam at 40% brightness as DRLs and got flashed by other drivers so often, I ended up turning them off........... Got - 2017 SDV8 Autobiography in Loire Blue
|  12th Sep 2013 9:31am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | I am able to demonstrate to plod that my "fog" lights are not on during the day/inapropriately, by the simple fact that
|  12th Sep 2013 1:10pm |
|  12th Sep 2013 1:12pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Hmmmmm...  | ||
|  12th Sep 2013 1:36pm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | And when they see Stan's avatar then you are absolutely sure they won't even considered charging you with anything  | ||
|  12th Sep 2013 1:39pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | |||
|  12th Sep 2013 1:48pm |
| 33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381      | You also need to have a very good look at where you want to put your switch. If my memory is correct there is stuff blocking that position from behind. Was going to put a switch there myself for driving lights But something stop me   | ||
|  19th Sep 2013 6:13am |
| Posting Rules
