![]() | Home > Maintenance & Mods (L322) > DRL's again ... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
the reason the police used to stop peeps with fogs on during the day was because the 55 watt power blinding on-coming traffic..replacing these with low power led bulbs for drl purposes is a logical step..
so how does one regard golfs with their main beams on low power, or porsches[?] with what looks like lower fogs on... ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
I used my IIDTool to set the main beam at 40% brightness as DRLs and got flashed by other drivers so often, I ended up turning them off........... Got - 2017 SDV8 Autobiography in Loire Blue
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I am able to demonstrate to plod that my "fog" lights are not on during the day/inapropriately, by the simple fact that
Hmmmmm... |
And when they see Stan's avatar then you are absolutely sure they won't even considered charging you with anything |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
You also need to have a very good look at where you want to put your switch. If my memory is correct there is stuff blocking that position from behind. Was going to put a switch there myself for driving lights But something stop me |
