Home > Technical (L322) > Can't see the tow-bar with the reverse camera - solution?
GregMilner
Australia 2012 Range Rover Westminster TDV8 Fuji White
Guys, I tow a large-ish boat quite often, and it's a pain not being able to see the trailer hitch as I back up to it. Can anybody point me in the direction of a thread which talks about fitting a camera that can actually see the tow bar, and plumbing the picture into the centre screen?
Post #210049 13th Sep 2013 2:07pm
ebajema
I have not heard of anyone being able to do that on the L322 and I think it is due to the location of the camera, it can't see around the edge of the tailgate.
Have you considered getting / using the Venture cam ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #210051 13th Sep 2013 2:10pm
GregMilner
Don't know what Venturecam is - much the same as GoPro? 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Gone: 2010 RRS 3.0 TDV6, 2007 Audi TT 3.2V6 Roadster
Post #210052 13th Sep 2013 2:13pm
you could get an aftermarket wireless camera/monitor or you could try and re-position the existing camera so it looks downwards more but i dont know if this possible..
there's a how to n the wiki re fitting an upgraded camera, maybe that will give you some ideas.. ... - .- -.
Post #210056 13th Sep 2013 2:26pm
ebajema
There are aftermarket solutions that allow for the camera to be built into the tailgate near the license plate lights or in the spot of one of them. Or you can move the camera of course. All these type of options take quite a bit of work and knowledge.
The Venture Cam is a Range Rover (Disco as well ???) camera that is a loose unit and can be placed outside the car or used hand held. It interfaces with the car via Bluetooth and shows on your screen. What I don't know is whether it is "overridden" by the rear view camera when backing up. But members that do have the venture cam may be able to tell you. The cam sits in a little cubby hole underneath the dashboard on the passenger side. MY 2010 5.0 SC Galway green and sand interior!!
Post #210060 13th Sep 2013 2:46pm
GregMilner
Excellent, thanks. I'm having a tow kit installed next week at the local Perth LR dealer so they may know something about it, I'll ask them. Thanks for the heads up, appreciate it. 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Post #210062 13th Sep 2013 2:49pm
something like this might help Greg,
http://www.ebay.co.uk/itm/9-IR-Wireless-Re...25773f3031 ... - .- -.
Post #210064 13th Sep 2013 2:52pm
ebajema
There are a few Venture cams for sale on Ebay (UK) as well. MY 2010 5.0 SC Galway green and sand interior!!
Post #210066 13th Sep 2013 2:55pm
GregMilner
Thanks Stan...looks like a cheap solution. It's a pity in one way though, I was hoping there might be a logical, built-in solution from LR. Seems strange to me that with all the tech they pack into these cars - RRS and Disco included - they fit reversing cameras that can't see the tow bar. Seems a bit weird considering one of the major uses of these cars is towing vans and boats. 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Post #210067 13th Sep 2013 2:56pm
you are absolutely correct Greg but there's a limit to LR's foresight.. ... - .- -.
Post #210069 13th Sep 2013 3:34pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Vision Assist/Tow Assist is the only way to do it. Saying that, with a bit of practice you should be able to do it alone without getting out if you use the same trailer all the time.
Post #210071 13th Sep 2013 3:41pm
ebajema
You can also put a catcher on the tow hook (someone on here did that), to make it easier. And a little antenna "stick" on the trailer so you have an aiming point.
In the US I saw a towbar that slides and hinges out. You drive close to the trailer, connect the bar by hand, drive forward and back and it locks in place. Can't for the life of me remember what it is called, where to get it etc., sorry. MY 2010 5.0 SC Galway green and sand interior!!
Post #210075 13th Sep 2013 4:19pm
Venture cam is not available / an option on TFT screen FullFat's 2008 MY Supercharged
Post #210076 13th Sep 2013 4:27pm
get a long stick with a small flag on it, stick it on the top of your tow ball using a magnet or sucker, so as you can see it in the rear view camera, then when it gets knocked off by the hitch on the boat you are in the right place........ something like this.
http://www.etrailer.com/Hitch-Accessories/Reese/53410.html
or the same thing on amazon
http://www.amazon.com/Trailer-Alignment-Ma...tching+aid There is nothing that can't be fixed with a hammer😜😜
Post #210084 13th Sep 2013 4:55pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I have been using the venturecam for trailer hitching (horsebox regularily [sp?]). I have been waiting for trailer assist for the L322 to come out but nothing seems to be moving on that front.
I have available camera channnels available via the touch screen - bluetooth?.
Are there different frequencies for blue tooth or are all assigned to one?.
My idea would be to add a fixed camera for attaching trailer and adding the ifor fixed camera.
Any tought on whether this would conflict n the available channels.
Or sould i order extra venturecams?, in the box i look aft forward - would prefer the wide angle forward aft fixed on....
Post #210291 14th Sep 2013 8:14pm
