Home > Technical (L322) > LED running lights
Page 1 of 3 123>
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
LED running lights
Looking at adding some bling to my car and adding running lights but not doing the LED headlamp conversion.
Does anyone have experience of adding these below the bumper within the black plastic insert mesh? Looking around you can buy them in Halforda and I've see them for as little as £4 on eBay...you can even buy strips that you place over the headlamps but I'm not sure these would work that well and may look cheap.
http://www.ebay.co.uk/itm/Universal-Pair-D...257e94ae76
Does anyone know where the wires would run to? Obviosuly they would run from the ignition feed but I'm curious as to whether I an do this myself relatively easily. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #210600 16th Sep 2013 8:07pm
Rich, i think you have to be careful as to what you put on the front of a FF as its very easy to make it look cheap & tacky my friend...£4 DRL's don't sound too classy on an originally £40k FFRR Rolling Eyes
Post #210603 16th Sep 2013 8:16pm
Rich86
I'm not contemplating the cheap ones hence why I'm looking of some advice and images...
Thumbs Up 2009 Vogue TDV8 Nara Bronze
Post #210607 16th Sep 2013 8:19pm
Thumbs Up Bow down Thumbs Up
Post #210611 16th Sep 2013 8:29pm
Fitting led rings inside tthe foglights is about as discrete as you can get.
http://www.fullfatrr.com/forum/topic11640.html?highlight=drls
Post #210615 16th Sep 2013 8:38pm
Rich86
Sounds like a plan but the images on the link aren't there anymore so I can't see the end result.
Very Happy 2009 Vogue TDV8 Nara Bronze
Post #210623 16th Sep 2013 9:12pm
Sorry about that, had a clear out of pictures.
If you click on "this" in the first post you will find Disco 3's fitted with them.
They look exactly the same on an FFRR.
Post #210624 16th Sep 2013 9:21pm
Rich86
Which first post? Sorry if I'm being thick... 2009 Vogue TDV8 Nara Bronze
Post #210625 16th Sep 2013 9:31pm
Third line down in the link in my first post. Thumbs Up
Post #210626 16th Sep 2013 9:33pm
Here is the link: http://www.disco3.co.uk/forum/topic61097.html?highlight .
Post #210628 16th Sep 2013 9:41pm
Rich86
Thanks guys. They look ok but how would these be wired and to what? 2009 Vogue TDV8 Nara Bronze
Post #210632 16th Sep 2013 9:56pm
If you go thro my post all the info about wiring and the bits you need is in there. Thumbs Up
Post #210635 16th Sep 2013 9:59pm
Rich86
Just read it and sounds quite complicated. I'm not that technical so I don't think I'd be any good splicing and soldering wires... 2009 Vogue TDV8 Nara Bronze
Post #210636 16th Sep 2013 10:05pm
paneldamage
I think DRLs could be added, if the design was right.... Seen some on a RRS that were set into the bumper, the owner said they were a Phillips item, it is one of those jobs that if done wrong, or poorly executed could really spoil things. You need the factory look....and just sticking them in the slots towards the centre of the car would be pointless and illegal
How about changing the spots to DRL, plenty of these on the bay?
Post #210638 16th Sep 2013 10:07pm
Rich86
Do you mean the fogs under the bumper as mentioned above? 2009 Vogue TDV8 Nara Bronze
Post #210643 16th Sep 2013 10:18pm
Page 1 of 3 123>
