Home > Technical (L322) > Car Chugging / Juddering.. But no loss of power
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Well had the FF for 5 months and took it for a run out from Manchester to North Wales
All was going sweet until I got on the A55 and doing between 60 - 70 mls per hour..
All of a sudden the car started to rumble and chug (I can only describe it has a rumbling/juddering) with no loss of power it lasted for a couple of minutes then stopped...... Then back to running sweet again..... Then happened again and again all the way to wales and back again...
As it is intermittent, I will have trouble describing it to a garage
Anyone had this happen to them or can advise on what it might be,,
PS - It is still under Warranty
Trev Current Cars
(Sold) Range Rover TD6 05 Vogue SE - 85k - Zambezi Silver - Black Leather..
Kia Ceed (4) 1.6 - 33k - Silver
Previous.
VW Golf 2008 2.0 SDI (With Add Ons) - 109k Silver
Vauxhall Zafira 2.2 Petrol SRI - with Ex Pack 32k -Turquoise (traded for the FFRR)
Post #208939 8th Sep 2013 8:50pm
Tricky one this. Rumbling/juddering.
Does it feel engine or gearbox?
There are a few threads on here re a sensation like a cattle grid, this would point towards a failing lock up clutch in the gearbox, however the fact it went away may point to more engine related problem.
Did it feel like it had lost power at the time almost like only running on 5 cyl. In which case it could point towards injectors.
Sure someone a lot more knowledgable will show up soon though. There is nothing that can't be fixed with a hammer😜😜
Post #208949 8th Sep 2013 9:36pm
Trev18
Thanks... Lots of info on here regarding the Cattle Grid symptoms.... I will start with that at the garage......and see what the have to say...
Trev Current Cars
Previous.
Post #208968 8th Sep 2013 10:35pm
ebajema
Maybe your fuel pump(s) are nearing the end of its/their lifespan and struggling to get enough fuel in. Just enough to not lose power but cause the juddering. Although I would expect some power loss in that case.
Have you checked the brakes ?? Signs of hot discs could be the infamous caliper issue (although that is more common on SCs) starting to act up.
What is the service history of the car ?? Gearbox, filters, fluids etc. ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #208996 9th Sep 2013 8:43am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Something similar for me which turned out to be the injector wiring loom.....
Post #209012 9th Sep 2013 10:07am
Trev18
Thanks guys - All options will be mentioned..
Booked in for Wednesday for a check over... I will let you know how we get on
Trev.. Current Cars
Previous.
Post #209023 9th Sep 2013 11:20am
Trev18
Update..
Well the lady was not playing up today...She was on her best behaviour
They had her plugged in - Nothing showing...
They took her for a long test drive trying to replicate the issue.. Nothing Showing..
It looks like its going to be a pain...... as he said she was running better than last time he saw her..
I will keep you updated....
Trev Current Cars
Previous.
Post #209629 11th Sep 2013 9:49pm
Rolling Eyes Think they call that sods law... Rolling Eyes
Post #209652 12th Sep 2013 12:08am
Trev18
Update...
Took her for a spin today and she was in mood again, Chugging away......
Managed to speak to the garage and drove her to him and got him to test drive it and see for himself..... Result.....
Part ruled out engine, and brakes whilst driving her...... and thinking something transmission....
Got her booked in next Thursday for him to give her another once over...
Trev.... Current Cars
Previous.
Post #210943 18th Sep 2013 4:20pm
Trev18
Update ---
Great point raised earlier by a forum member....ebajema ---- Got it spot on.....
"Have you checked the brakes ?? Signs of hot discs could be the infamous calliper issue (although that is more common on SCs) starting to act up."
Whilst in they gave it a thorough check from front to back..
The issue identified has the back right brake calliper was faulty... and was locking up.... and damaged the disk.. also the Wear Sensor was loose Evil or Very Mad !!!!........
Also identified.
NSF ball joint found to be worn
CV Boots insecure
Heater fan noisy when switched off....
Result.. Thumbs Up Thumbs Up Thumbs Up
Just picked it up... with the following supplied and fitted
2 new brake disks, brake pads and wire kit
Replacement of lower ball joint
CV boots secured... (I will be keeping an eye on these)
Replacement Heater Actuator...
Cost breakdown inc Fitting - Brakes £284.83 ..... Ball Joint and Heater £256.75
Result all covered by the garage.... Big Cry Big Cry Whistle
Has negotiated 12 months warranty with them before purchase. Thumbs Up Thumbs Up Thumbs Up
Previous.
Post #215185 8th Oct 2013 2:56pm
Glad it's all fixed. Well done on giving the updates along the way. All too often people have a problem, ask for advice but never say how it all ends.. Thumbs Up Previously..
Post #215187 8th Oct 2013 3:15pm
TugRR
Ref the rear caliper - is your an '06 MY by any chance ? If so, then it'll have the TRW calipers. Both mine have had the same problem. Both cars '06MY, but neither was an SC !
The first sign on mine was the economy plummeting . . . . I don't know how you find out on an SC - it probably changes from mpg to gpm Whistle
Thumbs Up Where do you go after one of these . . . ?
Post #215198 8th Oct 2013 3:56pm
ebajema
Cool !!! Glad you have it sorted !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #215203 8th Oct 2013 4:05pm
Trev18
Hi TugRR,
Not sure what you mean by 06MY.... or SC .....
Its a 55 plate Vogue SE...
I am looking forward to the better fuel economy........ Bow down Thumbs Up Thumbs Up Thumbs Up Whistle
Trev Current Cars
Previous.
Post #215327 8th Oct 2013 10:26pm
TugRR
Sorry Trev, we get wrapped up with terminology not everybody knows the meaning of !
By SC - I mean the supercharged cars.
BY '06 MY -I mean 2006 model year. If your VIN number has a 6A in it - if it's a 55 reg it probably will - it will be 2006 model year.
There were some anomalies around that time regarding powertrain, electronics, brakes etc.
It seems all models around that time have problems with the rear calipers sticking, regardless of engine type.
Post #215425 9th Oct 2013 1:32pm
