![]() | Home > Technical (L322) > Battery Charging Advice |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I can only help you with 3. There are battery terminals to use under the bonnet. You don't attach anything to the actual battery because of the pyro charge. I'd recommend a getting a full charge BEFORE trying to start the vehicle. Charging a very low battery is very hard on the alternator, and they aren't cheap. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
1 Yes
The drivers door does have a mechanical lock, sadly they usually seize and you can't get in when such an emergency arises |
If you have a tow bar and electrics of course you don't need to get into the car at all to charge the battery if the need arises.
hcire Member Since: 10 Aug 2012 Location: Virginia Posts: 44 ![]() ![]() ![]() |
I pulled the battery without incident, and the battery is now charging. Now I hope it takes a charge and there are no underlying electrical issues.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I have never heard of this before but it sounds pretty good. I have 13 pin and LR loom, can I simply get a spare 13 pin male and have 2 leads running from it ???... Is this where I put the car details and a bit about myself ?........ |
Have you seen this from our Glorious Leader ?
I hadn't.....but I can make one of those !
As long as you don't push more than 20amps into it I think you should be fine |
Would it be possible to put a 3 pin plug onto that and charge the battery from the mains? ![]() |
I wonder which would pop first... The rear fuse board or the battery.... |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
How do I buy one of those? I guess it just plugs into a ctek? Last edited by wealy on 28th Sep 2013 1:37pm. Edited 5 times in total |
Or optimate type charger? |
How do I buy one of those? |
